MONITOR and SDA series woofers
Gary Batson
Gary Batson Posts: 124
edited June 2007 in Vintage Speakers
Polk made a lot of 6.5 in. woofers for their monitor series and SDA series speakers that all look the same but different model numbers. Does anyone know the differences between these speakers and if any of them are interchangeable?
What are the new replacement woofers from Polk like? Do they look the same? I think I read somewhere that they're not sticky. I'm sure the originals were sticky for a reason.
Post edited by Gary Batson on
  • ben62670
    ben62670 Posts: 15,969
    edited June 2007
    There were a few 4ohms versions, and several 8ohm versions. The early MW6500 was very efficient, but bottomed out if overly driven. It slowly worked up to the 6503 which handled more power, and resisted bottoming out. As for the sticky part I don't know if the originals came sticky, or got sticky after a couple years.
    Ben
    F1nut Posts: 52,001
    edited June 2007
    All the drivers are designed with different specs and therefore are not really interchangeable. The original drivers came sticky and as far as I know the replacements are too.
  • Jockos
    Jockos Posts: 310
    edited June 2007
    Are the new replacements out already, ie 6510, 6502?
  • ben62670
    edited June 2007
    Jockos wrote: »
    Are the new replacements out already 6510ie?
    Nope I just ordered the other day.
    I don't know about the 6502
    Ben
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited June 2007
    Why are they sticky?
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • Gary Batson
    edited June 2007
    ben62670 wrote: »
    Yep; My SDA 1's were sticky the day I bought them in 1983. I'm surprised they haven't dried up after all these years. Some things are just better sticky.:D
    F1nut Posts: 52,001
    edited June 2007
    It's doped paper, which helps the cone keep it's shape.
  • Gary Batson
    edited June 2007
    Just a guess, But I think it was used as a damping material. Polk literature says they use a three layer cone construction. It must be one of the layers. And I've seen mentioned somewhere before about a damping material used in the cone.
  • Jockos
    Jockos Posts: 310
    edited June 2007
    I read somewhere that the sticky coating reduces resonance and leads to cleaner midrange.
    Jockos
