pioneer elite vsx-41 or harman kardon avr225
glemay
I have 2 polk audio rti70's and a psw202 sub. Which receiver out of the pioneer or the harman kardon is better which one should i buy?
Main System:
Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a
Second System:
Post edited by glemay on
I looked at both brands before, I would by the Pioneer Elite, just personal preference. I used to like HK stuff but in the past few years I've liked other brands better. If you want the HK check out ubid.com or HK's website you may be able to save some cash on a refurbished unit. My Onkyo was bought as a refurbished unit and it works fine.
Did you listen to both? Which sounds better to you? -
I've got the pioneer elite vsx-43 and love it. Sounds great with the polk speakers.
what's the difference between the 41 and the 43?Center; CS-400i
Main's; RT-55's
Side Surround's-RT-35's
Rear center;CS-300
Sub; SVS PB12-NSD -
About $400
Mains: Polk RTi70's
Center: Polk CSi40
Surrounds: Polk TC60i's
Sub: Polk PSW505
Receiver: Onkyo TX-DS696
TV: Samsung HLS 5687W 56"
DVD: Sony DVP S5300
Protection: Monster HTS 3600
Backup Battery: Belkin AP3080010 -
I have the H/K AVR-520 and I like it. Some may say that H/K have problems, but what receiver dosn't have a problems. I had Onkyo and had problems, I had Pioneer that had a problems, My sony had problems. And I know that I will have problems with the H/K but just remember no matter what you buy you could have problems, some more then others but still can be fixed.
