I need an education in CDP
JimBRICK
Ok guys I need to know.
#1 what I am looking for in a good cdp.
#2 what makes a good cdp and a not so good cdp
#3 what are the better names
#4 If I go tube cdp, do I need tubes in the other elctronics to hear the difference?
thanks for any info.
Jim
Jim
2 CHANNEL
Speaker - Klipsch Heresy II
Under construction
Under construction
Post edited by JimBRICK on
#1 sound
#2 sound, sound
#3 What is your price range? Sony, Rega, Jolida and many more
#4 no~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
I like solid build. I have never seen a cheap CD player built solid. It's a good indicator.
Tons of brands; Cambridge, Rotel, Music Hall, Shanling, Cary, Musical Fidelity, Jolida, Sony, Rega, yada, yada, yada....Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
NAD is always a good choice."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
Bryston will be introducing their first player the BCD1 very soon.http://www.bryston.ca/pdfs/07/BCD-1CD.pdf.Testing
Testing
Testing -
what about the pioneer elite models?2 CHANNEL
Under construction -
How much are you looking to spend and what do you have now?
You could always forgo adding a new CDP and go with a new DAC and use the current unit as a transport.
As for the Elites I have no experience with the cd players but have had a 47ai for about 4 years now. It was there top of the line DVD player when I purchased it and it is a great unit. Sound quality wise it is good but was beaten by my Jolida, and also by a Squeezebox with a cheap NOS DAC.
There is also the squeezebox route which I know at least a few members here embrace the main one of the top of my head being Joey_V.
Jared -
my current nakamichi cannot use a DAC cause I have no digital outputs. It only 1 set of analog outputs
This thing is a tank and I love it. the model number is CDP-2A. it a single disc with the green lights and readers on the front. I got it for 30 bucks and its in MINT condition.
I'm using the Pioneer Elite A35-R integrated amp. So I figured I'd follow suit with a matching cdp. Hooked into the mirage sm-1 vintage speakers I got.
This is for the budget 2 channel rig I put together that sound amazing and surprised the hell outta me.
120 for the pioneer, 30 for the nak, 25 for my yamaha phono and 30 for the mirages you cant go wrong
I found the nak on ebay
http://cgi.ebay.ca/Vintage-Nakamichi-Compact-Disc-Player-CDP-2A-NR_W0QQitemZ290126010004QQihZ019QQcategoryZ3284QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
is this a good player?2 CHANNEL
Never heard it but Steve listed some great choices. What is your budget?
JT -
Careful with a tube CDP with a solid state preamp. I had two really good tube CDPs in my rig and my Spectral pre hated both of them. It just was bad synergy. The only way to find out is to hooked it up to your rig and listen for a good week.
my budget right now I dont want to spend more than 150 bucks. I want to keep this a budget system2 CHANNEL
Oppo DV 970HD; for $150 you can't miss with this.
I have a pioneer elite pd-65. It's a great sounding cd player that's built like a tank.SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once. -
I was jsut reading about that player it looks wild2 CHANNEL
my favorite CDP is the yada, yada, yada one.
:rolleyes: PolkFest 2012, who's going>?
Keep the Nakamichi if you like it. My ex had a Nakamichi OMS-2??? I think? It was a very smooth sounding player, but also very fussy about scratches/imperfections. Terrible error-correction circuit.
IMO, the best "econo-CDP's" are the less expensive Sony's, hands down. I could put a $129 Sony in my system tommorrow, and be fine with it.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
I'm thnking about the sony in the fm2 CHANNEL
Have you looked at the Oppo reviews? That sounds like a strong choice for your budget?Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Sony's have real good rythm/pace. They make the music enjoyable. The down side is that the cheaper models can sound a little brittle in the high's at loud volumes. They're great players.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I love my Pioneer Elite PD-59 player. I also have other ones but my Pio Elite still sounds the best and I love the stable platter mechanism.Display: Sony XBR3 46"
Pre/Pro: Marantz AV7005
Amplifiers: Anthem MCA20 / Anthem MCA30
CD: Pioneer Elite PD59 / Sony XA20ES / Denon 755AE
DVD: Denon 3930CI
BD: Pioneer Elite 05FD
Sat: Bell TV 9241HD
Game: Sony PS3 60GB
Media Streamer: WDTV Live Hub
Power Console: Panamax 5300PM
Speakers: Paradigm Reference Studio v.3
Subwoofer: SVS 16-46PC+
Preamp: Parasound P3
Amplifier: BAT VK60 Tube
Sacd: Sony 777ES
Power Console: Ultralink PGX-500
Speakers: Paradigm Reference Studio 20 v.5 -
Keep the Nak I'd bet most $150 players will sound worse and many much worse. I've owned many Nak cdp's (still have one) and for their day they were outstanding and built like brick sh*thouses. Sure the technology is better today but not in a budget cdp. Use the Nak until it dies. I wish my OMS 4A still worked to use in my second system.
Sounds like it may have an issue. All the Naks I sold and owned from that era had great error correction. They used the latest Sony derived optics and e/c back then. Although many older players the Nak's included don't like cdr's and will either show an error in the display or skip like a ****.
