SDA1c or SDA-SRS2 for tube amp
ben62670
ben62670 Posts: 15,969
edited June 2007 in Vintage Speakers
What do you guys think would work better with a vintage pioneer tube amp? My buddy has the option for either.
SDA1c = 6ohms
SDA-SRS2's = 4ohms
Thanks Ben
Ben
Post edited by ben62670 on
  • WilliamM2
    WilliamM2 Posts: 4,806
    edited June 2007
    SDA1C's are also 6 ohms.
    SDA's sound better with a lot of power, how much does the Pioneer have?
  • ben62670
    edited June 2007
    WilliamM2 wrote: »
    I have to edit now:o
    Ben
  • engtaz
    engtaz Posts: 7,669
    edited June 2007
    srs2
    engtaz
  • ESavinon
    ESavinon Posts: 3,067
    edited June 2007
    The sda 1c are better for a tube amp. Out of the two, the 1c are more musical.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • ben62670
    edited June 2007
    Thanks E
    I don't know much about his amp except that it is old, and pioneer. 4ohms kinda scares me.
    Ben
    Ben
  • ESavinon
    edited June 2007
    Which version of the srs 2 or the sda 1c do you have?
  • ben62670
    edited June 2007
    Its for my buddy up in CT. He has the option of getting the 1c's or the twin blade SRS 2's. I have had a few different versions. SDA2's, 2A's, and the 3.1TL's. I have also built some different verities. I am presently building these here.
    http://www.polkaudio.com/forums/showthread.php?t=53273
    Thanks again
    Ben
    Ben
  • ESavinon
    edited June 2007
    The blade/blade versions of these two sda speakers are rated at 4ohms.
    The pin/blade versions are 6 ohms.
  • ben62670
    edited June 2007
    ESAVINON wrote: »
    He is looking at the blade blade.
    Ben
  • ESavinon
    edited June 2007
    Both versions sound different from each other.
    The pin/blade versions have different drivers and a simplified crossover.
    I have both the 1c and the srs 2 in both blade/blade and pin/blade versions.
    I prefer the pin/blade versions.
  • Face
    Face Posts: 14,340
    edited June 2007
    Just send the SDA-SRS2's to me, that'll solve his problem.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited June 2007
    The SRS 2's will slay the 1C's.
    I drove mine for quite a while with a modded Anthem Amp 1. 40w, push pull EL34. GREAT pairing of amp and speaker.
    Cheers,
    Russ
  • ben62670
    edited June 2007
    Thanks E
    I do value your opinions, and will pass the info on to my friend.
    Ben
    Ben
  • ben62670
    edited June 2007
    RuSsMaN wrote: »
    Cheers,
    Russ
    Ah crap! I also trust Rman's opinion too!
    I guess I stick around on this one!
    Ben
    Ben
  • avguytx
    avguytx Posts: 1,628
    edited June 2007
    ESAVINON wrote: »
    Not always. I have SDA 1C's that are blade/blade and are 6ohm. The connector for the IC is not on the terminal cup but below it a few inches. Ken said it was running changes that just happened midstream. On page 28 of the SDA Compendium it says..."Some of the first SDA 1C speakers used the same cabinet style as the 1B (using up old parts again?). Some of the first SDA 1C's also used a blade/blade interconnect cable than a pin/blade cable."
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • ESavinon
    edited June 2007
    RuSsMaN wrote: »
    Cheers,
    Russ
    They're both great speakers.
    I love the way the srs 2 sound with video. I find the 1c better for music.
    The srs2 are more dynamic,analitical with a wide soundstage while the 1c are more laid back with a deeper yet narrower soundstage.
  • ben62670
    edited June 2007
    I hope that was just the first few. I would have him test them with an ohmmeter. He knows how to use one.
    Ben
  • ESavinon
    edited June 2007
    avguytx wrote: »
    I can't argue with the sda bible.
  • engtaz
    engtaz Posts: 7,669
    edited June 2007
    Dang I feel like low man on the totem pole for suggesting SRS2. LOL
    engtaz
