SDA1c or SDA-SRS2 for tube amp
ben62670
What do you guys think would work better with a vintage pioneer tube amp? My buddy has the option for either.
SDA1c = 6ohms
SDA-SRS2's = 4ohms
Thanks Ben
SDA1c = 6ohms
SDA-SRS2's = 4ohms
Thanks Ben
Ben
Ben
Post edited by ben62670 on
SDA1C's are also 6 ohms.
SDA's sound better with a lot of power, how much does the Pioneer have? -
I have to edit now:oPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
The sda 1c are better for a tube amp. Out of the two, the 1c are more musical.SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once. -
Thanks E
I don't know much about his amp except that it is old, and pioneer. 4ohms kinda scares me.
Ben -
Which version of the srs 2 or the sda 1c do you have?SRT For Life; SDA Forever!
Its for my buddy up in CT. He has the option of getting the 1c's or the twin blade SRS 2's. I have had a few different versions. SDA2's, 2A's, and the 3.1TL's. I have also built some different verities. I am presently building these here.
http://www.polkaudio.com/forums/showthread.php?t=53273
Thanks again
Ben -
The blade/blade versions of these two sda speakers are rated at 4ohms.
The pin/blade versions are 6 ohms.SRT For Life; SDA Forever!
He is looking at the blade blade.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Both versions sound different from each other.
The pin/blade versions have different drivers and a simplified crossover.
I have both the 1c and the srs 2 in both blade/blade and pin/blade versions.
I prefer the pin/blade versions.SRT For Life; SDA Forever!
Just send the SDA-SRS2's to me, that'll solve his problem."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
The SRS 2's will slay the 1C's.
I drove mine for quite a while with a modded Anthem Amp 1. 40w, push pull EL34. GREAT pairing of amp and speaker.
Cheers,
Thanks E
I do value your opinions, and will pass the info on to my friend.
Ben -
Cheers,
Russ
Ah crap! I also trust Rman's opinion too!
I guess I stick around on this one!
Ben -
Not always. I have SDA 1C's that are blade/blade and are 6ohm. The connector for the IC is not on the terminal cup but below it a few inches. Ken said it was running changes that just happened midstream. On page 28 of the SDA Compendium it says..."Some of the first SDA 1C speakers used the same cabinet style as the 1B (using up old parts again?). Some of the first SDA 1C's also used a blade/blade interconnect cable than a pin/blade cable."Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner. -
Cheers,
Russ
They're both great speakers.
I love the way the srs 2 sound with video. I find the 1c better for music.
The srs2 are more dynamic,analitical with a wide soundstage while the 1c are more laid back with a deeper yet narrower soundstage.SRT For Life; SDA Forever!
I hope that was just the first few. I would have him test them with an ohmmeter. He knows how to use one.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I can't argue with the sda bible.SRT For Life; SDA Forever!
Dang I feel like low man on the totem pole for suggesting SRS2. LOLengtaz
