Can you test an amp without a tuner?
Face
Face Posts: 14,340
I believe I read that you could hook a cd player directly up to a power amp to test it. I know I'll have to turn the gain to 0 and slowly increase it till I hear sound.
The reason I ask it, I may have found a deal on a nice amp, but he already sold his pre-amp and I don't feel like dismantling my system.
TIA,
Post edited by Face on
  • AndyGwis
    AndyGwis Posts: 3,655
    edited June 2007
    I usually test amps with my iPod, because it has volume control on it.
    Plug adapter into iPod, plug adapter into amp, turn iPod on, make sure volume is all the way down, turn on amp, pick a song, play song, slowly turn volume up.
    Anyway, that's how I do it. If you hook up a CDP without gain/volume control, make sure your amp has gain/volume control. If neither has gain control, I'd find another solution.
    I had my old Sony ES (CA80ES) hooked up directly to my amp for a while, but even at it's lowest volume setting (on the CDP), it was already at a moderate volume level.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Face
    Face Posts: 14,340
    edited June 2007
    I didn't even realize I have a PDA that will work, thanks!
  • AndyGwis
    edited June 2007
    Good luck. If it blows up, I hope you do not hold me personally liable :)
  • danger boy
    danger boy Posts: 15,722
    edited June 2007
    either your CDP has to have variable audio outputs or your amp has to have gain controls to be able to do this correctly.. either way. turn the amp volume all the way down. and use crappy speakers just in case.
    PolkFest 2012, who's going>?
  • Face
    Face Posts: 14,340
    edited June 2007
    I'm now the proud owner of a immaculate Mcintosh MC-7270.
    Now time to build a 2 ch. rig around it. :D
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited June 2007
    mmmmmmmmmmmmmm....One day I will flirt with Mac gear...
