Help with Binding Post Nuts
Jockos
Jockos Posts: 310
edited June 2007 in Troubleshooting
I'm redoing my HT sytem and putting banana plugs in. On my R15s I tried removing the black plastic plugs in the posts and broke the red nut. My question is 2 fold.
1. How do you remove the black plugs from the posts safely.
2. Can I replace the broken red nut? I tried to screw the remaining piece off but it doesn't back out.
Help please Jockos
Post edited by Jockos on
  • danger boy
    danger boy Posts: 15,722
    edited June 2007
    to remove the plastic plugs.. use a thin blade knife.. doesn't have to be a sharp one. and wiggle it under the plastic plug cap... lift it up and out.. should come out with a little force.
    Or drill it out with your drill.. that's what I did a while back. works like a charm. ;)
    PolkFest 2012, who's going>?
  • McLoki
    McLoki Posts: 5,231
    edited June 2007
    It is a little easier than that. Just unscrew the nut all the way until it comes off. The plug is just a cap and will pop right off (can use a fingernail). Then screw the red or black nut back on. :)
    Michael
  • sucks2beme
    sucks2beme Posts: 5,691
    edited June 2007
    Many posts dont screw off all the way.
    If the post is broken, most of the time you can pull the whole assembly
    out of the speaker with a couple of screws. The whole post is normally
    held on with a nut and washers, with the speaker lead tied on with a
    spade or eyelet connector and another nut. Rarely, the wire is soldered on.
    In a few cases, it's mounted directly on the x-over board.
    I believe the R series will require a small phillips screwdriver, nutdriver,
    or 1/4 inch socket set to remove. Easy fix.
    Check Ratshack for replacement posts.
    Home depot has outlet faceplates with posts.
    Remove from cover and re-use!
  • Jockos
    Jockos Posts: 310
    edited June 2007
    Thanks, maybe Ken has a few lying around.
  • ViperZ
    ViperZ Posts: 2,046
    edited June 2007
    Thanks so much for posting this... I installed banana plugs on all of my wires, except for the ends that go to R15s - never realized that those "caps" will just come out.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • sucks2beme
    edited June 2007
    Seems euro power plugs fit in 5 way speaker posts. That's why the idiot plugs
    are installed on many modern speakers. Whoops.
  • Jockos
    Jockos Posts: 310
    edited June 2007
    Well that explains why polk in their owners manual says that only US owners should remove the plugs!
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited June 2007
    Hello Jockos,
    Sorry you're having problems with the R15 binding posts. The binding posts are part of the speaker's crossover network, which is found on the other side of the input cup. The crossover network attached to the input cup is part number RE1010-1 and the Club Polk price is $12.80 plus your local state sales tax, no charge for second day shipping. Just telephone 1-800-377-7655 to place an order, mention your Clup Polk membership.
    Regards, Ken
  • Jockos
    Jockos Posts: 310
    edited June 2007
