How loud do you listen?
  • Serendipity
    Serendipity Posts: 6,975
    edited May 2007
    I think 115db is a bit too loud...better save your hearing and listen at a few db lower; just my opinion.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • amulford
    amulford Posts: 5,020
    edited May 2007
    Isn't pain threshold of a NORMAL human being 115 db?
    Define normal...
    And that's with HALF of the power I plan to use. I could probably go higher, but it starts breaking up, and those **** are expensive to fix. I think the extra power will allow me to reach my intended goal with much better control.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2007
    amulford wrote: »
    Define normal...
    Is your intended goal deafness??:D :p
    VR3 Posts: 29,436
    edited May 2007
    Sterilization is actually the true goal..
  • Serendipity
    edited May 2007
    115db wouldn't do the trick..
  • Schwingding
    Schwingding Posts: 363
    edited May 2007
    Was just checking that earlier tonight. 80-82db at about 9.5 feet for music.
    I have 10db of hearing loss between 2-8Khz though, from racing loud cars and boats, and constant tinnitus that is noticeable up to 50db before it gets drowned out by other sounds.
    HT/music rig
    Panasonic PX60U 50" plasma
    Yamaha 5990 AVR
    Onix SP3 tube amp
    bunch of Outlaw 2200 monoblocks
    DUAL SVS PB12+/2 subs :eek:
    Denon 3910 DVD/SACD/DVD-A
    DirecTV HR10-250 DVR
    Onix Strata Mini mains
    Mirage OM10 surrounds
    Polk CSi5 center
    Polk SC80 rear surrounds
    Samsung BDP1000 blu-ray player
    Bedroom rig
    Jolida SJ302a tube amp
    Denon 2910 universal player
    Onix Ref 1 monitors
    Velodyne minivee
  • Serendipity
    edited May 2007
    Just checked today. Ever since I got my new speakers I listen a bit louder now, around 70-75db.
  • goingganzo
    goingganzo Posts: 2,793
    edited May 2007
    when my ears start to blead i turn it up 1 more notch
  • Lowell_M
    Lowell_M Posts: 1,660
    edited June 2007
    I just checked this weekend. When listening at a "comfortable" level for long term listening I seem to be around 85dB. When I am doing critical listening, or showing off my system, it looks like I am around 100dB. .....I haven't turned it up to "drunk party" levels yet to see yet, but 100dB was -18dB on my H/K and I generally end up ramping the volume up to -10dB when friends are over partying.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
