Computer to TV issue
NeilGabriel
NeilGabriel Posts: 1,487
This is a little off topic, but a couple weeks ago, I wanted to see what it looked like to run my computer through my HDTV. I am certain that all I did was connect an s-video cord from the laptop to the TV and selected the appropriate input. Up pops my desktop on the TV screen and I played a couple videos...but resolution was really bad.
So...tonight, my wife and I want to look at some hi rez pictures on the TV, but now I cannot get anything on the laptop to appear on the TV screen. The s-video works (tried it with the dvd) and the input is proper. Tried 2 laptops and neither will display on the TV. Help please before I jump out the basement window!! I see something in Help about a monitor wizaed, but I never used this the last time I connected to the TV.
THE ANSWER IS THAT YOU HAVE TO CONNECT THE LAPTOP TO THE TV BEFORE YOU TURN THE LAPTOP ON. S-VIDEO HAS A WHOLE WEBSITE!
Post edited by NeilGabriel on
  • Serendipity
    Serendipity Posts: 6,975
    edited May 2007
    Yes, you have to do that. Some video card drivers allow you to connect the laptop to the TV after you turn the laptop on, but not ALL can do this.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • ben62670
    ben62670 Posts: 15,969
    edited May 2007
    Also some Laptop have a function key that enables TV
    IE alt+function key, ctrl+function key.
    Ben
