Does it really make a difference if u upgdare CD/DVD power cord ?
kolyan2k
kolyan2k Posts: 259
edited May 2007 in Electronics
if you use IEC adapter and a better power cord ?
http://www.vhaudio.com/acplugadapters.html
this guy saying it will:
http://www.epinions.com/content_251258834564
Post edited by kolyan2k on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited May 2007
    Try it yourself and find out.
  • Early B.
    Early B. Posts: 7,900
    edited May 2007
    Yes.
    "God grooves with tubes."
  • Sherardp
    Sherardp Posts: 8,038
    edited May 2007
    i notice a difference on my Marantz CC4001 when I upgraded the ICs and power cord. I went with signalcable. Give it a shot, if you dont notice a difference you will at least have a solid cable that looks very good.
  • Early B.
    edited May 2007
    I realize you're an electrician and after market power cords probably don't make much sense to you, but suspend everything you've learned about electronics and try it for yourself.
  • Spacedeckman
    Spacedeckman Posts: 96
    edited May 2007
    I built my own out of 12/3 SJT (heavy extension cord) and the plug from the big box lumber yard. Sourced an IEC from a local electonic supply house. Took some Dremel work on the IEC, but soldered everything in place instead of screws, shrink wrapped it, and viola', DIY power cord.
    I was impressed enough that I built one for each piece of equipment I had. I wasn't expecting anything either. Dropped the noise floor and opened things up a bit.
    Mark
    System:
    VPI Scout/Benz Ace
    Sutherland PH2000
    Arcam CD72
    Yamaha DVD-CX1 (primarily for CD..26 lbs, all BB D/A)
    Audioprism Mantissa w/Reference PS
    Parasound HCA750 (temporary)
    Audiovector M1 Signatures
    Kimber 4TC x 2
  • kolyan2k
    kolyan2k Posts: 259
    edited May 2007
    Early B. wrote: »
    i will do that. and i will make my own power cord to replace 18 AWG cord that i have right now with 14 or 12.
  • aaharvel
    aaharvel Posts: 4,489
    edited May 2007
    depends on the quality of the gear i suppose. I've always wanted to know if a powercord would make a difference with my amp, I just don't know if it would justify the cost/labor considering the speakers I power it with.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • Schwingding
    Schwingding Posts: 363
    edited May 2007
    Do any of you folks in the "YES IT MAKES A BIG DIFFERENCE" category live in/near Baltimore? If so, I would like to drop by and do a blind "taste test" with you and your fancy power cords.
    Seriously. If you can tell the diff more than 50% of the time I will believe you. Other than that, its more snake oil.
    HT/music rig
    Panasonic PX60U 50" plasma
    Yamaha 5990 AVR
    Onix SP3 tube amp
    bunch of Outlaw 2200 monoblocks
    DUAL SVS PB12+/2 subs :eek:
    Denon 3910 DVD/SACD/DVD-A
    DirecTV HR10-250 DVR
    Onix Strata Mini mains
    Mirage OM10 surrounds
    Polk CSi5 center
    Polk SC80 rear surrounds
    Samsung BDP1000 blu-ray player
    Bedroom rig
    Jolida SJ302a tube amp
    Denon 2910 universal player
    Onix Ref 1 monitors
    Velodyne minivee
  • halo
    halo Posts: 5,616
    edited May 2007
    F1nut has extended an open invitation to all naysayers. He's in MD.
    LINK - Post #44
    F1nut Posts: 51,764
    edited May 2007
    Well, the power cord situation here might be a little difficult to conduct blind tests with. My main rig uses 20 amp IEC ends on the gear, which in turn run into 2 separate UPC-200's each with it's own power cord running to the outlets. In addition to that, each time the gear is powered up it takes about an half hour to reach optimum operating temperature. However, the office rig is a possibility for power cord swaps.
