Does it really make a difference if u upgdare CD/DVD power cord ?
kolyan2k
if you use IEC adapter and a better power cord ?
http://www.vhaudio.com/acplugadapters.html
this guy saying it will:
http://www.epinions.com/content_251258834564
Try it yourself and find out.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Yes.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
i notice a difference on my Marantz CC4001 when I upgraded the ICs and power cord. I went with signalcable. Give it a shot, if you dont notice a difference you will at least have a solid cable that looks very good.Shoot the jumper.....................BALLIN.............!!!!!
I realize you're an electrician and after market power cords probably don't make much sense to you, but suspend everything you've learned about electronics and try it for yourself.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I built my own out of 12/3 SJT (heavy extension cord) and the plug from the big box lumber yard. Sourced an IEC from a local electonic supply house. Took some Dremel work on the IEC, but soldered everything in place instead of screws, shrink wrapped it, and viola', DIY power cord.
I was impressed enough that I built one for each piece of equipment I had. I wasn't expecting anything either. Dropped the noise floor and opened things up a bit.
MarkSystem:
VPI Scout/Benz Ace
Sutherland PH2000
Arcam CD72
Yamaha DVD-CX1 (primarily for CD..26 lbs, all BB D/A)
Audioprism Mantissa w/Reference PS
Parasound HCA750 (temporary)
Audiovector M1 Signatures
Kimber 4TC x 2 -
i will do that. and i will make my own power cord to replace 18 AWG cord that i have right now with 14 or 12. -
depends on the quality of the gear i suppose. I've always wanted to know if a powercord would make a difference with my amp, I just don't know if it would justify the cost/labor considering the speakers I power it with.
Do any of you folks in the "YES IT MAKES A BIG DIFFERENCE" category live in/near Baltimore? If so, I would like to drop by and do a blind "taste test" with you and your fancy power cords.
Seriously. If you can tell the diff more than 50% of the time I will believe you. Other than that, its more snake oil.HT/music rig
Panasonic PX60U 50" plasma
Yamaha 5990 AVR
Onix SP3 tube amp
bunch of Outlaw 2200 monoblocks
DUAL SVS PB12+/2 subs :eek:
Denon 3910 DVD/SACD/DVD-A
DirecTV HR10-250 DVR
Onix Strata Mini mains
Mirage OM10 surrounds
Polk CSi5 center
Polk SC80 rear surrounds
Samsung BDP1000 blu-ray player
Bedroom rig
Jolida SJ302a tube amp
Denon 2910 universal player
Onix Ref 1 monitors
Velodyne minivee -
Video: LG OLED77B4PUA * Sony BDP-S470 * Roku Ultra * APC H10 -
Well, the power cord situation here might be a little difficult to conduct blind tests with. My main rig uses 20 amp IEC ends on the gear, which in turn run into 2 separate UPC-200's each with it's own power cord running to the outlets. In addition to that, each time the gear is powered up it takes about an half hour to reach optimum operating temperature. However, the office rig is a possibility for power cord swaps.
