Samsung DLP picture went bad.
Skynut
Skynut Posts: 2,967
edited August 2007 in Electronics
Less than a year old my DLP picture has a bar going down the right side of the screen.
It started with a small shadow on the right about 3" wide from top to bottom, now it is about 20" wide with the farthest right 10" being darker.
It really sucks to watch, every day it is a little worse.
I called Samsung and they set me up with a local authorized repair shop and sent them a confirmation by fax that they can repair it. I have an appointment this afternoon between 4 and 6 pm with an in house repair guy.
At first it looked like something fell into the path of the light but now I think the bulb might be going bad.
We shall see.
I will say that Samsung customer service was very helpful and easy to deal with so lets see if they fix the problem with little or no hassle.
Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking
Post edited by Skynut on
«13
    billbillw Posts: 7,580
    edited May 2007
    Doubt its a bad bulb. I think they just quit all together. Sounds like a "light engine" problem. The little DLP chip isn't doing what its supposed to. At least its under warranty. Good luck. It sucks to loose your TV. I went through a 3 month ordeal with Toshiba back in 2005. Eventually they replaced my entire set with the newer model.
  • Skynut
    Skynut Posts: 2,967
    edited May 2007
    This thing was expensive, it should not have problems already.
    My Toshiba was a rear projection and lasted over ten years, the only problem I ever had was a blown fuse.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • JimBRICK
    JimBRICK Posts: 1,543
    edited May 2007
    I stopped selling samsung last sept after 3 out 5 of the customers I sold the same dlp had issues in the first 6 months
    2 CHANNEL
    Speaker - Klipsch Heresy II
    Under construction
  • Skynut
    Skynut Posts: 2,967
    edited May 2007
    Great.
    It was one of the most affordable sets when we bought it.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • scottvamp
    scottvamp Posts: 3,277
    edited May 2007
    Expensive has very little to do with reliability. I have stayed away from DLP from the get go. Way too much can go wrong. In my opinion, once you go with a "bulb" based engine, should just go front projection anyway. Even with my projectors for the last 7 years i have stuck with LCD. And yes CRT based rear projection last. I am on my second one. The first one i sold to a friend and it still has plenty of life. My dad had a 52" RCA. Lasted 12 years and had over 80,000 hours on it. The power supply eventually failed.
    Hope it works out for ya.
  • Fireman32
    Fireman32 Posts: 4,845
    edited May 2007
    Sorry to hear that. I have had no issues with my mits dlp aqnd its over 2 years old. Good thing you have the warranty.
  • bobman1235
    bobman1235 Posts: 10,822
    edited May 2007
    Sorry to hear that Sky, but I agree with Sammy's customer service. When I first got my DLP it kept shutting itself off, they sent someone to my house within 2 days, in a nice small time window, and they replaced the whole light engine nice and quick (since they couldn't figure out what was wrong or reproduce the problem).
  • Skynut
    Skynut Posts: 2,967
    edited May 2007
    This problem is easy to reproduce. :D
    I am waiting for him now, any time between 4 and 6.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited May 2007
    Mine did the same thing. I am on my third light engine. I will never again buy any DLP. I will wait until something simpler comes along.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Skynut
    Skynut Posts: 2,967
    edited May 2007
    Great.
    They just left with my set and said it is the engine.
    This sucks, how much are the engines once it is out of warranty next month?
    At least I have the Visio LCD I won last year to do fill in work.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
    edited May 2007
    Skynut wrote: »
    Great.
    The warranty repair will have its own warranty. Not sure how long, probably depends on the service company and/or Samsung. I'd definitely ask though.
  • wingnut4772
    edited May 2007
    Skynut wrote: »
    Great.
    I don't know but that's why I got the extended warranty from the store. I am sure they are crazy expensive though.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • phipiper10
    phipiper10 Posts: 961
    edited May 2007
    Good luck, keep us posted. So far 2+ years with Samsung DLP and no issues.
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • Skynut
    Skynut Posts: 2,967
    edited May 2007
    It is good to hear that someone with a Smasung is not having trouble.
    I am hoping this is a fluke and I will not have any more problems.
    I am also hoping that I can change the engine myself next time.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • rhulett
    rhulett Posts: 89
    edited May 2007
    It sounds like you have a collapsing light tunnel, they've had a quite a few problems with the first builds of their dlp's. Here is a LINK over at avs of people who have had this happen. I would think with a little nice talk, they should fix it for free with all of the problems that they've had.
    Rob
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited May 2007
    JimBRICK wrote: »
    My picture just went out one night out of the blue....It has been eight weeks now, and it SHOULD be back by Friday.....I will never deal with CC again...Worst customer service ever! They change their tune if you call them everyday though....They really hate me now.
  • MSALLA
    MSALLA Posts: 1,602
    edited May 2007
    My sammi was 2 years old in April. First set they gave me had a problem form jump. But cc gave me another set no questions asked and I have not had a problem since.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • Skynut
    Skynut Posts: 2,967
    edited May 2007
    I have not heard from the service shop yet, I would not be supprised if something was in the way of the light source.
    I am interested in what they say it was after they fix it.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • Bill Ayotte
    edited May 2007
    Skynut wrote: »
    I'm really interested to find out what was replaced in mine too....I guess the engine was bad, but after they replaced that, they found a problem with a board...My guess is that those morons broke something putting it back together, then just said that they had another problem...The contractor CC has here is absolute crap...I really just wish that they would have replaced my set after 5 weeks of trying to get the **** to come pick up the dead one to fix it...We will see how it plays out this afternoon....
  • Serendipity
    Serendipity Posts: 6,975
    edited May 2007
    Happens all the time. I personally know 2 people who have had their DLP sets go bad.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Sherardp
    Sherardp Posts: 8,038
    edited May 2007
    Time for front projection if your room can handle the large screen, that Sony VPL VW50 looks good over at Vanns for 3700.00
  • scottvamp
    edited May 2007
    Front Projection rules! Thats all i gotta say.:D
  • goingganzo
    goingganzo Posts: 2,793
    edited May 2007
    we have a loder rp dlp samsung and it is great but i bought a new samsung lcd 40 in hd and had nothing but backlight problems from the start
  • Serendipity
    edited May 2007
    I have a front projection setup, but it's not an LCD/DLP; I have a CRT projector. No bulbs to replace, no filters to clean, no lamp failures...all is good with a CRT projector.
  • Sherardp
    edited May 2007
    CRTs are awesome, just big and bulky IMHO. But I have to admit they throw an awesome pic. I just viewed a Barco out here at a Japanese Video Store and it had the wow factor. I just dont have the time to maintain them etc. For me the JVC was a no brainer, some compare it to a CRT, but again thats a different argument that I choose not to get into here with CRT owners.
  • Skynut
    Skynut Posts: 2,967
    edited June 2007
    So I call the shop today to see what's the holdup and the guy tells me that Samsung no longer replaces the whole engine and he has to figure out which part went bad.
    He replaced something I can't remember now and that wasn't it so now he is replacing the "tunnel" where the picture goes through.
    I may get the set back monday.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • Skynut
    Skynut Posts: 2,967
    edited June 2007
    rhulett wrote: »
    Rob
    This sounds like what he is talking about at the shop.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • wingnut4772
    edited June 2007
    Skynut wrote: »
    That may work in your favor because if your repair guy can't figure it out and deems it to be 'un-repairable' you will get a whole new set.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • Skynut
    Skynut Posts: 2,967
    edited June 2007
    That would be nice.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • Bill Ayotte
    edited June 2007
    I just got my dead set back a few minutes ago.....I get to go get a new one Monday, when the actual manager is there...It has been three months now, at least I am getting a new current model with the extended warranty FREE, because of the way I was treated by their repair contractor...I am also receiving a free stand, due to the fact that my old set has an integrated stand, and the fact that it took three months to get to this point...:mad:
