Dedicated DVD player
NeilGabriel
NeilGabriel Posts: 1,487
edited May 2007 in Electronics
I have always been suspicious of players that attempt to play every format. I also don't like to pay for the ability to play formats I don't intend to use. Are there new/used dedicated DVD players that play just dvd (and maybe cd) that go for less than $1000 and that would make a big improvement over my Panasonic S77 (HDMI and upconverts)?
Post edited by NeilGabriel on
  • steveinaz
    steveinaz Posts: 19,545
    edited May 2007
    No. Most anything above the budget range is going to be "universal" these days. You'd probably have to go to a Denon 3910 or higher to best your S77---even that would be arguable.
  • venomclan
    venomclan Posts: 2,467
    edited May 2007
    I think the OPPO 970 at $150 is a killer machine from every review I have seen. The Cambridge Audio DVD players and the Denon 19xx series players are also very good.
    Being universal in many cases does not take away their ability for good dvd playback, and with costs ever decreasing, the extra format playability is usually just gravy.
    v
  • polkatese
    polkatese Posts: 6,767
    edited May 2007
    seconded Oppo 970. A respectable contender to several higher priced players that I have.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
    billbillw Posts: 7,469
    edited May 2007
    I don't think the Oppo 970 is going to be any better than the Panny S77. That S77 is a great little dvd player. You won't get much better unless you move up to the expensive Denons, which of course are universal players. Stick with what you got.
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    Great advice billbillw
    engtaz
  • NeilGabriel
    edited May 2007
    billbillw wrote: »
    my wife blesses you....I am sitting here listening to a great CD on the new HT separates with the vintage monitors all around....life is good....if only my knees would quit hurting....
  • Systems
    Systems Posts: 14,873
    edited May 2007
    I would keep the Panny until the Blue Ray /HD DVD wars settle down and prices fall further on those players.
    Testing
    Testing
    Testing
