psb speakers
JimBRICK
JimBRICK Posts: 1,543
edited May 2007 in Speakers
who has heard these speakers???
I have a dealer in town who is going to be carrying them soon should I be excited?
2 CHANNEL
Speaker - Klipsch Heresy II
Under construction
Post edited by JimBRICK on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited May 2007
    I like them. Not as bright as Paradigm can be, kind of like a Canadian Polk.
    I've had several older models, and currently run an Alpha series system for the HT rig.
    Cheers,
    Russ
  • engtaz
    engtaz Posts: 7,671
    edited May 2007
    Canadian Polk
    Is the a new type of sound? LOL
    engtaz
  • NeilGabriel
    NeilGabriel Posts: 1,487
    edited May 2007
    A few years back...oh 1993... I was about to buy a used set of Monitor 10s for about $300 when my local audiophile dealer persuaded me to buy psb 300 for something like $130 a piece....a bookshelf speaker that the alpha succeeded as I recall. They are good but not as good as the 10s. A couple years ago (now in the current milennium) I listened to some high end psb's when I bought my Monitor Silver 6s. The psb's were incredible but almost twice as much. As you probably know PSB is Paul S. Barton. Don't know if it is still family owned or not.
  • Systems
    Systems Posts: 14,872
    edited May 2007
    PSB has been in buisness since the early 70's and were the first company to utilize the famed NRC for the R&D work.They make some very good sounding products and their entry level models offer excellent value.
    Testing
    Testing
    Testing
  • Systems
    edited May 2007
    Barton is still the big cheese but I believe the majority ownership is by Lenbrook who also own NAD.
    Testing
    Testing
    Testing
  • Yashu
    Yashu Posts: 772
    edited May 2007
    The Alpha is a great bookshelf speaker for the money. The Image line would make for an *awsome* high end HT system... The old Stratus line are revered for their pleasing warm sound, and were damn good speakers for their time, the new Platinum and G series, I don't know a lot about... but I understand they are pretty good.
    I have owned several PSB speakers, and their sound is very neutral to slightly dark. Their sound is one that measures very well for the money, but is not for everybody because, at least I found, that it was hard to get the emotion that is so important. At the same time, that makes them, at least the Alpha, Image, and the old Stratus, forgiving. I liked them anyway, and I still use a set of Alpha Ts for 2 channel HT...
    I always recommend PSB to newbie audiophiles, esp. the Alpha B, since it is cheap, has a great response curve, and are like 92db sensitive @ 8 ohms so you don't need a huge amp.
