If i have an amplifier with output stage of 3ohm, What kind of speaker could I add?
charliez
charliez Posts: 72
Hi you all, I need an advice.
My sister has a sony HTIB, the amp and speakers impedance is 3 ohm 100w.
But she is not happy with the stereo soundstage, so what kind of speaker she could add??
- If I connect an 8ohm speaker, what could happen?
- Or must to connect a 4 ohm speaker
She don´t want to blow the amp :)
I´m waiting for your comments!
Post edited by charliez on
  • scottdwagner
    scottdwagner Posts: 106
    edited May 2007
    Not to be disrespectful, but if she's really into optimizing the soundstage, I think the only sound advice would be to relegate the HTIB to the bedroom and start again from scratch. You're just not going to gain that much by adding better speakers to what I assume is a subpar foundation. Just my opinion. YMMV
    Monitor Audio GR 60, GR10, GRLCR
    Velodyne HGS18
    Emotiva MMC-1
    Parasound Model 5250
    Denon DVD-3800
    Pioneer pdp-5070
    Secondary HT with B&W CDM-NTs all around and Rotel Separates (thanks Venom!)
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited May 2007
  • AndyGwis
    AndyGwis Posts: 3,655
    edited May 2007
    Third. I doubt many HTIB receivers realistically do 3-ohm loads. More likely, the manufacturer gives estimated specs at 3-ohms to make the wattage seem greater. At least, that's what I'm thinking.
    Stay around here, save a bit of money, then rebuilt a new system. If you do some research, make wise purchases, etc., you can put together a much better system for less than you'd think.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited May 2007
    The 3 ohm speakers may be used in series with a 3 ohm sub. You can replace the 3 ohm satellites with a better 4 ohm speaker. Your results will be dependent on the amplifier's ability to power the better/larger speaker, so I wouldn't expect much.
    Most HTIB rigs are generally matched gear that doesn't play well with others.
  • charliez
    charliez Posts: 72
    edited May 2007
    Yeah, I agree with you all. Since I have a pair of R15´s I just wondering if I can hook to a sony. But 8ohms against 3 ohm. mmm....
    tks
