Grill cloth coming loose
Phil Dawson
The grill cloth on my SRS SDAs is coming loose for a bit on one side. It looks like it was glued down when it was new. What type of glue should I use to get the cloth back down? What type of glue did Polk use?
Thanks for any help, Phil
Post edited by Phil Dawson on
Hello,
Thanks for posting on our Forum. You should be able to usehot melt glue to re-attach the cloth.
Regards, Ken -
Thanks for your help, Phil
this might help: LINKAudio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
Somehow I read the title as "girls clothes coming loose". Thoroughly disappointed.
