Best way to burn in new amp?
snow
snow Posts: 4,358
edited May 2007 in Electronics
Whats the best way to burn in a new amp? I recieved the proton D-1200 amp today and it is basically new with only 2 hours total use on it, It still smells like a new amp with the plastic /rubber heating up in it.
REGARDS SNOW
Post edited by snow on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited May 2007
    Lighter fluid... then stand back.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • snow
    snow Posts: 4,358
    edited May 2007
    disneyjoe7 wrote: »
    I will keep that in mind..... if all else fails lol
    REGARDS SNOW
    heiney9 Posts: 25,450
    edited May 2007
    disneyjoe7 wrote: »
    Charcoal and some mesquite wood chips on a slow burn.
    Seriously, just play it often and leave it on for awhile (meaning don't turn it on for a 1/2 hour and off for 2 hours then back on again, etc.) Really not sure there is a proper way to burn electronics in. Me personally, I tend to leave things on rather than turning them off and on. If I'm home for most of the weekend the system goes on and stays powered up all weekend.
  • snow
    snow Posts: 4,358
    edited May 2007
    Thanks H9. Thats pretty much what I did with the carver before this amp and it seemed to work well. Figured i should ask though in case there was a reccomended # of hours on and levels etc. heres a pic of its new home for now at least.
    REGARDS SNOW
    edited May 2007
    That is a sweet amp. I remember several years ago flipping thru a Crutchfield catalog I wanted to get some Proton stuff. Essentially an offshoot of NAD sometime before AMC Welltronics. I never did get to listen to any Proton stuff back when they were popular. I occasionally check e-bay for an unit at a rock bottom price, but those are usually abused. Certainly something I don't need but would like to give a listen to someday.
  • snow
    snow Posts: 4,358
    edited May 2007
    heiney9 wrote: »
    Thanks. They are one of the few things I am passionate about in audio. The lighting in this room isnt the best, tried like hell to capture a decent pic lol. Heres another pic.
    REGARDS SNOW
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2007
    heiney9 wrote: »
    I leave mine on 27 x 7. I had to turn just the amps off for a little while last week cause I was Dynamating the spokes in my mid-woofers and passive radiator baskets.
    The only other time I will turn them off is if a thunderstorm is brewing.
  • hearingimpared
    edited May 2007
    snow wrote: »
    REGARDS SNOW
    Nice. Someone told me back in January that I should put a CD on repeat mode and leave the volume down low and just let it continue until I was ready to listen. Then after listening, put the CD back on loop and let it continue on low.
    I couldn't do it cause I got so impatient to hear my rig, and remember, I hadn't heard a good rig in my own home for 17 years prior to, that after about 45 minutes I just started to listen and the first week I had my rig going I was in that room day and night, night and day. My wife then got on a kick and was listening to the rig 4 hours a day. . . so the break in time was shortened!!!!
  • snow
    snow Posts: 4,358
    edited May 2007
    What is the dynamating, some sort of damping material? oops I just noticed that the reflection caught part of my shoulder. I was stark **** naked while i was taking that pic, could have been far worse though.:D :eek: :D
    REGARDS SNOW
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    nice amp pretty light "ops I just noticed that the reflection caught part of my shoulder. I was stark **** naked while i was taking that pic, could have been far worse though" bad imaging LOL
    engtaz
  • Polk65
    Polk65 Posts: 1,405
    edited May 2007
    disneyjoe7 wrote: »
    [X] Mark
    [X] Antny
    [X] Steve
    Ted you're gonna have to keep an eye on these three.
  • hearingimpared
    edited May 2007
    snow wrote: »
    REGARDS SNOW
    Dynamat is this asphalt based material that is used for dampening automobiles from the woes of the dreaded trunk subwoofer LOL. It comes is sheets and can be cut to practically any size you would need. It is a PITA when using it in the application I employed it. I had to cut 64, 1 1/4" x 2 1/2" pieces for the 16 mid-woofers and then 16, 1 1/4" X 5" pieces for the passive radiator.
    It similar to sorbothane sheets with one difference. Dynamat is pretty much like formed tar. Once it's applied it is a **** to get off. Plus is gets under you fingernails and well you can imagine. The day after I did the job I walked out of the shower and was drying myself and found some in my hair and what I thought was a scab on my ear was a stuck piece of Dynamat LOL!!
    BTW I'm very glad I did the job no matter how tedious, hand cramping or backing breaking. . . I got an audible improvement in my mid-range.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited May 2007
    Are you on the lunar time table or something :D
  • disneyjoe7
    edited May 2007
    Polk65 wrote: »
    [X] Mark
    [X] Antny
    [X] Steve
    De-Rail alert...
    Well I think you're right Antony just plain nuts, I'm Crazy, Mark smart and a bit nuts. The three of us could be dangerous. ;) :eek: :eek: :eek:
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • hearingimpared
    edited May 2007
    Polkmaniac wrote: »
    WAAAAAAAAAAAAAAAAAA 24 X 7 I'm not going to edit out the first posting of 27 LOL!
  • snow
    snow Posts: 4,358
    edited May 2007
    engtaz wrote: »
    Thanks eng. Yes that would be a bad image lol. REGARDS SNOW
  • snow
    snow Posts: 4,358
    edited May 2007
    Thanks joe I learn something new every day.:)
    REGARDS SNOW
  • Ron Temple
    Ron Temple Posts: 3,212
    edited May 2007
    Nice wire management :p ... looks just like mine ;)
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • snow
    snow Posts: 4,358
    edited May 2007
    Yes lol. I was looking at it this morning telling myself what a mess.:p I figure that at some point I am going to cut the speaker wires to the proper length and take some wire ties and bundle some of the assorted connections together. And put a backer behind the stand to hide most of the rats nest :D
    REGARDS SNOW
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    Once you try to hide, the rats nest gets worse. Trust me.
    engtaz
  • hearingimpared
    edited May 2007
    snow wrote: »
    REGARDS SNOW
    Don't make the speaker wires any less than 8' . . . don't ask me why either!!! LOL
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2007
    I usually hit the power button and go do something else for a week.
  • wallstreet
    wallstreet Posts: 1,405
    edited May 2007
    Play it crazy loud. If it breaks, you would want to know sooner rather than later.
  • snow
    snow Posts: 4,358
    edited May 2007
    Ok thanks joe.
    REGARDS SNOW
  • snow
    snow Posts: 4,358
    edited May 2007
    dorokusai wrote: »
    Thanks doro. I cant wait a week to listen to it though.:p I will leave it on for a week though 24/7
    REGARDS SNOW
  • hearingimpared
    edited May 2007
    snow wrote: »
    REGARDS SNOW
    I guess you didn't learn from the earlier post it is 27x7 lunar time.LOL
  • Systems
    Systems Posts: 14,873
    edited May 2007
    snow wrote: »
    Put a 330nf cap across the outputs and feed it a 3khz square wave for 100hours.;)
    Testing
    Testing
    Testing
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited May 2007
    Why would an amp that is amost 20 years old need to burn-in?
  • snow
    snow Posts: 4,358
    edited May 2007
    WilliamM2 wrote: »
    The answer is hidden in post#1 :p Its because its basically NOS it only had a few hours total usage.
    REGARDS SNOW
  • hearingimpared
    edited May 2007
    Actually Bro now that I reread your first post, since this is so old and has been fired up before, and run for only a few hours, you should wake it up slowly. When I first took my Spectral out of storage, (20 years of storage) I called Spectral and asked the engineer there if there was anything in particular that I should do before firing the preamp up. He told me to pop the top and make sure no dust or mosture had accumulated and then advised me to get a variac and slowly wake it up.
    I believe I started a thread on it back in like August actually here it is . The thread has instructions on making a poor man's variac but I had lucked out in that LibertyC (Billy) had a variac that he lent me. I woke the preamp up slowly over two days.
    If you haven't pluged it in yet for a long period of time you may want to consider doing this. One of the main reasons the engineer at Spectral said to do this was to slowly reform the caps and slowly get the circuitry stabilized by adding varying degrees of voltage to it over periods of time.
    Sorry I didn't think of this earlier.
