AVR for LSis
Polk & H/K
Best AVR for LSi 15 & LSI 7s in rear? L.I. H.I. F.I. says NAD T 753.
Post edited by Polk & H/K on
Just do a search of the forum. There are tons of threads dealing with this topic.
I think you will find that most will recommend using a preamp/processor (or AVR with preouts) and seperate amp or amps.
Adcom, Rotel, Parasound, Sunfire, Carver, Outlaw, etc...HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
I have no room for a pre/pro it must be an AVR.
The NAD would be a fine choice.
Others you could consider would be: Outlaw, Rotel, Denon, H/K, Pioneer Elite, Yamaha, Onkyo.HT
2 CH
Then the LSis aren't for you. You really need a separate amplifier so it can focus on powering the power-hungry LSi15s.
That's not to say that there aren't any AVRs out there that are capable of doing the job, but you'd be spending thousands more than you need to. I would not recommend the NAD 753... though NAD makes great stuff, I don't imagine the 70 wpc would be enough to power four LSis. -
I have the H/K 635 and love it. But the H/k will not drive 4Ohms.
How are you limited for space? Maybe you could stack an amp and pre/pro for space conservation?
The NAD T753 gives 200 watts dynamic power in 4 ohms.
The NAD T763 puts out 300 watts dynamic power in 4 ohms. The LSi 15s max watts is 250 what more do you need?
The nad receiver will do fine. It'll probably handle them better than the h/k, but then again I've never heard the h/k pushing anything better than a pair of rti10's. Yes, seperates might be better but you can always move onto them later if you have more space.
Polk & H/K wrote: »The NAD T763 puts out 300 watts dynamic power in 4 ohms. The LSi 15s max watts is 250 what more do you need?
Do some searches around the forum. You'll find that their rated power is significantly underrated. Many members throw 500+ watts @ 4ohms at these speaks.
Not to say an AVR won't be capable of handling these, but they really are meant for separates. -
Start with the NAD T763. It will drive them better then your HK. The issue with the 4ohm speakers is current (amps) the more the better.I was running 9's, 7's and Lsic off my Rx-v2500 (130 @ 8ohms) and it worked. The amp section in the NAD is much better then the Yammi but still might not bring out the true performance of the Lsi's.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880 -
The LSi series doesn't need outboard amplification to sound excellent....buy the right gear in the first place. The LSi bar for me is high current, 4ohm load capable, all channels driven.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
To be honest, I was not really happy with the laid back NAD and laid back LSI combination for movies. I swapped out the opamps in my NAD (changing the sound character of it) and love the sound I am getting now.
Different strokes for different folks. In my case it was using an NAD pre/pro so it had nothing to do with the amplification part of my system.
Just wanted you to be aware of it. (many other have used NAD AVR's with LSi speakers and love the sound so I may be in the minority here...)
McLoki - I don't think your off base at all. NAD gear is laid back/warm to me also....but that's my preference overall.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Polk & H/K wrote: »Best AVR for LSi 15 & LSI 7s in rear? L.I. H.I. F.I. says NAD T 753.
Well, "Best" is rather subjective. I am currently using a Sony DA7100ES, before that a Sony DA5000ES, and before that a Denon 3805. They all work fine and sound excellent, but the 7100ES is the "best" of this group.
Also, I used to have LSi15s in front and LSi7s as surround, but I upgraded the 7s to 15s in January. -
Pre/pro: Anthem Statement D2
7-Ch Amp: Sunfire TGA 7400
AVR's will not drive LSi's. Seperates are THE way to go. Actually AVR's won't drive RTi's too well either. In all honesty seperates are the way to go with all HT speakers. -
JoshParsons84 wrote: »Pre/pro: Anthem Statement D2
Because everyone knows that if you purchase polk audio's midline (or god forbid top end) speakers, they will sound like **** unless you have over $11,000 worth of electronics behind them.
Thanks for the clarification there.
Michael
Edit - read my book recommendation in this thread - then read the book (maybe a few times)...Mains.............Polk LSi15 (Cherry)
That's just ridiculous. AVR's won't drive the 8 ohm RTi's well?
Absolutely ridiculous and uninformed.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
My H/K 635 drives RTi 6s as well or better than most low end amps.
The ignorance that the Internet makes available for all to read is amazing. -
I don't know, I have the NAD T773 AVR & I don't think there's much out there speaker wise that it wouldn't drive.
Just make sure it has plenty of optical and coxial audio inputs.engtaz
Well I said that because if you want the most out of whatever speaker you got, use an external amp.
OK fine, you drive LSi (4ohm) off your receiver instead of a pre/pro and amp and report back and tell me how long it took for you to burn up your receiver or fry your speakers.
If your friend comes to you with a budget of $15,000 for the audio side of a home theater and you direct him to break up his budget as $4,000 for speakers and $11,000 for electronics - he needs to find a new friend.
anyone can suggest the top of the line. The difficult part of audio is getting something above average for whatever the current budget happens to be. For many of us - that is where Polk comes into play...
JoshParsons84 wrote: »OK fine, you drive LSi (4ohm) off your receiver instead of a pre/pro and amp and report back and tell me how long it took for you to burn up your receiver or fry your speakers.
I take it that you don't have any personal experience with NAD products. If you did you wouldn't be making such a ridiculous statement. -
You know as much about hi-fi as my dog.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Dang, lets play nice already. LOLengtaz
3 1/2 years and counting, running 9's, 7's, and LSiC off an ancient Denon 2802. As long as you use common sense, and not drive the AVR into clipping, it will be fine. Work within the limits of the receiver, until you can upgrade.
