AVR for LSis
Polk & H/K
Polk & H/K Posts: 29
edited May 2007 in Speakers
Best AVR for LSi 15 & LSI 7s in rear? L.I. H.I. F.I. says NAD T 753.
Post edited by Polk & H/K on
«1345
  • cmy330go
    cmy330go Posts: 2,341
    edited April 2007
    Just do a search of the forum. There are tons of threads dealing with this topic.
    I think you will find that most will recommend using a preamp/processor (or AVR with preouts) and seperate amp or amps.
    Adcom, Rotel, Parasound, Sunfire, Carver, Outlaw, etc...
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • Polk & H/K
    edited April 2007
    I have no room for a pre/pro it must be an AVR.
  • cmy330go
    edited April 2007
    The NAD would be a fine choice.
    Others you could consider would be: Outlaw, Rotel, Denon, H/K, Pioneer Elite, Yamaha, Onkyo.
    HT
    2 CH
  • dane_peterson
    dane_peterson Posts: 1,903
    edited April 2007
    Then the LSis aren't for you. You really need a separate amplifier so it can focus on powering the power-hungry LSi15s.
    That's not to say that there aren't any AVRs out there that are capable of doing the job, but you'd be spending thousands more than you need to. I would not recommend the NAD 753... though NAD makes great stuff, I don't imagine the 70 wpc would be enough to power four LSis.
  • Polk & H/K
    edited April 2007
    I have the H/K 635 and love it. But the H/k will not drive 4Ohms.
  • dane_peterson
    edited April 2007
    How are you limited for space? Maybe you could stack an amp and pre/pro for space conservation?
  • Polk & H/K
    edited April 2007
    The NAD T753 gives 200 watts dynamic power in 4 ohms.
  • Polk & H/K
    edited April 2007
    The NAD T763 puts out 300 watts dynamic power in 4 ohms. The LSi 15s max watts is 250 what more do you need?
  • michael_w
    michael_w Posts: 2,813
    edited April 2007
    The nad receiver will do fine. It'll probably handle them better than the h/k, but then again I've never heard the h/k pushing anything better than a pair of rti10's. Yes, seperates might be better but you can always move onto them later if you have more space.
  • dane_peterson
    edited April 2007
    Polk & H/K wrote: »
    Do some searches around the forum. You'll find that their rated power is significantly underrated. Many members throw 500+ watts @ 4ohms at these speaks.
    Not to say an AVR won't be capable of handling these, but they really are meant for separates.
  • MSALLA
    MSALLA Posts: 1,602
    edited April 2007
    Start with the NAD T763. It will drive them better then your HK. The issue with the 4ohm speakers is current (amps) the more the better.I was running 9's, 7's and Lsic off my Rx-v2500 (130 @ 8ohms) and it worked. The amp section in the NAD is much better then the Yammi but still might not bring out the true performance of the Lsi's.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2007
    The LSi series doesn't need outboard amplification to sound excellent....buy the right gear in the first place. The LSi bar for me is high current, 4ohm load capable, all channels driven.
  • McLoki
    McLoki Posts: 5,231
    edited April 2007
    To be honest, I was not really happy with the laid back NAD and laid back LSI combination for movies. I swapped out the opamps in my NAD (changing the sound character of it) and love the sound I am getting now.
    Different strokes for different folks. In my case it was using an NAD pre/pro so it had nothing to do with the amplification part of my system.
    Just wanted you to be aware of it. (many other have used NAD AVR's with LSi speakers and love the sound so I may be in the minority here...)
    Michael
  • dorokusai
    edited April 2007
    McLoki - I don't think your off base at all. NAD gear is laid back/warm to me also....but that's my preference overall.
  • bbeacham
    bbeacham Posts: 141
    edited April 2007
    Polk & H/K wrote: »
    Well, "Best" is rather subjective. I am currently using a Sony DA7100ES, before that a Sony DA5000ES, and before that a Denon 3805. They all work fine and sound excellent, but the 7100ES is the "best" of this group.
    Also, I used to have LSi15s in front and LSi7s as surround, but I upgraded the 7s to 15s in January.
  • JoshParsons84
    JoshParsons84 Posts: 565
    edited April 2007
    Pre/pro: Anthem Statement D2
    7-Ch Amp: Sunfire TGA 7400
    AVR's will not drive LSi's. Seperates are THE way to go. Actually AVR's won't drive RTi's too well either. In all honesty seperates are the way to go with all HT speakers.
  • McLoki
    McLoki Posts: 5,231
    edited April 2007
    Because everyone knows that if you purchase polk audio's midline (or god forbid top end) speakers, they will sound like **** unless you have over $11,000 worth of electronics behind them.
    Thanks for the clarification there.
    Michael
    Edit - read my book recommendation in this thread - then read the book (maybe a few times)...
  • Nostalgic
    Nostalgic Posts: 42
    edited April 2007
    That's just ridiculous. AVR's won't drive the 8 ohm RTi's well?
    :confused:
  • dorokusai
    edited April 2007
    Absolutely ridiculous and uninformed.
  • Polk & H/K
    edited April 2007
    My H/K 635 drives RTi 6s as well or better than most low end amps.
  • bbeacham
    bbeacham Posts: 141
    edited April 2007
    The ignorance that the Internet makes available for all to read is amazing.
  • pearsall001
    pearsall001 Posts: 5,249
    edited April 2007
    I don't know, I have the NAD T773 AVR & I don't think there's much out there speaker wise that it wouldn't drive.
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    Just make sure it has plenty of optical and coxial audio inputs.
    engtaz
  • JoshParsons84
    edited April 2007
    Well I said that because if you want the most out of whatever speaker you got, use an external amp.
  • JoshParsons84
    edited April 2007
    OK fine, you drive LSi (4ohm) off your receiver instead of a pre/pro and amp and report back and tell me how long it took for you to burn up your receiver or fry your speakers.
  • McLoki
    McLoki Posts: 5,231
    edited April 2007
    If your friend comes to you with a budget of $15,000 for the audio side of a home theater and you direct him to break up his budget as $4,000 for speakers and $11,000 for electronics - he needs to find a new friend.
    anyone can suggest the top of the line. The difficult part of audio is getting something above average for whatever the current budget happens to be. For many of us - that is where Polk comes into play... :)
  • pearsall001
    edited April 2007
    I take it that you don't have any personal experience with NAD products. If you did you wouldn't be making such a ridiculous statement.
  • dorokusai
    edited April 2007
    You know as much about hi-fi as my dog.
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    Dang, lets play nice already. LOL
    engtaz
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited April 2007
    3 1/2 years and counting, running 9's, 7's, and LSiC off an ancient Denon 2802. As long as you use common sense, and not drive the AVR into clipping, it will be fine. Work within the limits of the receiver, until you can upgrade.
