Stacking equipment and heat
NeilGabriel
NeilGabriel Posts: 1,487
Okay...now you will wonder how I have lived so long and not destroyed equipment. My HT stand (which is simply a huge HDTV stand) has only two shelves. I put the big **** amp in the lower shelf and the preamp in the upper second shelf. I stuck my DVD on top of the preamp. The preamp generates a lot of heat (which was news to me since I didn't realize this would happen). And the DVD always makes a little heat as well. I assume instead of just putting a spacer between them, I should just get the DVD player off the preamp, eh? The only real option is on a speaker....also bad idea, eh?
Post edited by NeilGabriel on
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2007
    At LEAST do a spacer until you figure something else out. Anything cheap will work but I thought these were pretty cool and inexpensive.... http://avrisers.net/default.aspx
    F1nut Posts: 51,749
    edited April 2007
    You could move the amp to an amp stand on the floor, which would free up some shelf space.
  • NeilGabriel
    edited April 2007
    Thanks for the suggestions (and this was not piss poor planning on my part--mostly)....just a cheap TV stand I bought a couple years ago. I'll see if I have clearance for a riser. I might even be able to move the amp, though I am not sure I can get it close enough without all new interconnects...in fact, I am sure I can't....I think moving the DVD would have to be the option...then a trip to the anti-christ of furniture stores....NFM...if you have not been to one, think big, very big. P.S. It is usual for a preamp processor to run warm...it seems to be much warmer than the amp.
  • vonnie123
    vonnie123 Posts: 326
    edited May 2007
    DC Fans can assist the cooling process. I installed four of them on my setup which I purchased a couple of years back on ebay. My equipment runs a little warm, but nothing excessive.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2007
    When I absolutely, positively have to stack because I've run out of rack space, I use Mapleshade Isoblocks. They are about 2 inches high and they are light in weight. They are only $24 per four.
  • snow
    snow Posts: 4,358
    edited May 2007
    dorokusai wrote: »
    I use these myself, there made by a fellow over at the carver forum btw. Heres a pic.
    REGARDS SNOW
