i need help with my subwoofer
bobby33
ok my speaker was working fine until a few days ago. then it started to smell like it was burning and it still smell like it. it works fine til a point.. it has dual hookup (i mean like it has a positive and a negative on both sides of the magnet) and on one side when i hook it up it shuts off the stereo but the other side works ok.. but not like it use to. someone please help!
Post edited by bobby33 on
Sounds like you blew a voice coil, but I'm not expert."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
is there anyway to take the speaker apart to fix it?
What kind of sub do you have?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Brand and model definitely would help.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
its a infinity reference series. it is 1200 watts
