4 Channel Amp, 2 sets of speakers and a sub
  • MacLeod
    MacLeod Posts: 14,358
    edited April 2007
    If thats the only amp youre running, your battery will be fine.
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited April 2007
    do you have an alternator in that boat?
    If not, then you really shouldn't be running anything besides a 15 watt headunit. If you've got at least a 60 amp alternator, then you should be perfectly fine.
    The Artist formerly known as PoweredByDodge
  • glemay
    glemay Posts: 574
    edited April 2007
    im pretty sure i've got a 65 amp alternator on the boat. Well thats good to know, thanks.
    Main System:
    Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
    Second System:
    Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a
  • Jstas
    Jstas Posts: 14,997
    edited April 2007
    Most boats have either an alternator or generator and a full charging system just like cars. Otherwise, your fuel would outlast your battery charge and it would suck to be stuck on the water with no power. The only time I haven't seen a boat with a charging system of some sort in the recent past was on a little, Johnson outboard that was freaking ancient and needed a gigantic Deka deep-cycle marine battery to get 4 hours of operation out of the engine. Thankfully he replaced it with a Mercury 9 I think it is and that has an electrical system.
    Expert Moron Extraordinaire
  • glemay
    glemay Posts: 574
    edited May 2007
    Hey guys,
    Well I just picked up the MTX TC4004 amplifier along with the Infinity Reference 1050w subwoofer. It's pretty sweet, got a decent deal on it too, lol. Hopefully I can start building the box tomorrow and start wiring the amplifier.
    As for the wiring of the amplifier, is there any thing specific that I should do? There is not much mentioned in the owner's manual. Fuses? Anything else? I want to make sure I have this wired the right way.
    What about the box? First time building a sub box, any pointers?
    Thanks guys,
    Gerry
    Main System:
    Second System:
  • glemay
    glemay Posts: 574
    edited May 2007
    Well, all the equipment is installed and running. It sounds awesome. I will try to post some pics later if you guys are interested.
    cya
    Main System:
    Second System:
  • PoweredByDodge
    edited May 2007
    Glemay,
    Sorry I didn't reply to your last post, but as far as installing and such, the only thing that is really 'essential' is that you have a fuse on the + power cable within 18 inches of the battery. For what you're running, I would say a 60 amp should be about right...
    I'd love to see some pics... haven't seen a boat install in a long time. :)
  • Z5ay
    Z5ay Posts: 1
    edited October 2012
    It would be rougly 50 watts for each of the 4 speakers and 200 watts to a single SVC 4 ohm sub.
    -MacLeod
    Dear MacLeod,
    Do you know if I could do this with a Kicker DX200.4?
    50watts x 4 channels
    Bridged 100watts x 2 channels
