Prewiring basement
jgrog
:rolleyes:
I've just framed my basement, have not even chosen system components. What speaker wire would you recommend to run through walls/ceiling?
Post edited by jgrog on
Belden cable 5000UE Grey jacket for $.38 a foot + Shippings seems to be a winner for price and sound. Not very pretty but remember it's in a wall.
You can get it at Blue Jean Cables http://www.bluejeanscable.com/store/speaker/index.htm
BTW Welcome and stick around.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Thanks. This looks like a good altenative to Monster cable.
disneyjoe7 wrote: »Belden cable 5000UE Grey jacket for $.38 a foot + Shippings seems to be a winner for price and sound. Not very pretty but remember it's in a wall.
This is the wire that I just used in my basement. Very nice cable. Easy to pull, seems to perform well, although I have nothing to compare it to.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables -
You definately don't want to use Monster cable for what you are doing. The jacket isn't made for pulling through studs and you will most likely tear it up.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Yep, using the same wire here for my surrounds. Works good at a good price!
I use monoprice.comengtaz
Thanks you guys. I'm just starting to research systems, and realize that this is another language. I travel, especially for events like Katrina or Mt. St. Helens to quantify the air chemistry...soooooo...I'll re-enter your environment off and on....As the rainbow man in Woodstock told me when I was a young kid...
Particles and Waves Baby! Particles and waves....
Thanks Again! -
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
I don't know if this is any help.When I did my basement I knew I was going to use a dropped ceiling acoustical tile system. I hadn't laid out the theater so I just ran a 3/4" pvc pipe connected to an electrical wall box. I located these every eight feet around my basement. I then just placed a box cover on them and now I can use any configuration I want. I can move the speakers around to play with the sound stage.The conduit just goes vertical between the studs and now the cable is protected agains drilling. I made all of the wiring crossovers above the ceiling. I can upgrade or change the wire with ease any time I want. It worked fine for me, just my 2c. Don't forget to make a few of the boxes big enough to handle the speakers configs with your setupHome Theater
Amp: sunfire cinema grand signature 5ch 425 wpc
Side surround amp: Sunfire 2 X 300
Processor: sunfire theater grand V
Fronts:: polk sda-srs 1.2
Rears: Polk LSiFX
Side surrounds: Fxi5
Center: (2)polk LSiC's
Sub: svs pb-13 rosenut
Hd-Dvd: toshiba xa-2
Blue Ray: oppo bdp83se
Projector: sony vw60
Screen: Da-Lite 106"
APC S20 Power conditioner
