Surround or SB?
Sansui
Sansui Posts: 372
My Dinon 887 amp supports 7.1 but I'm using a 5.1 speaker setup. Should I have my back speakers hooked up to the "Surround" or "Surround Back" speaker connections? Does it matter?
Be gentle, I'm new to all this...
The mind blowing speed of the BRAIN TRAIN...
Post edited by Sansui on
  • engtaz
    engtaz Posts: 7,674
    edited April 2007
    i like it. Most movie are only 5.1.
    engtaz
  • gvg45
    gvg45 Posts: 53
    edited April 2007
    5.1 set-up on a 7.1 AVR usually calls for surrounds to be hooked up to the "surround" connections. 'Surround Back" is usually used for either multi-room or the addition 2 channels if you decide to go 7.1
  • Sansui
    Sansui Posts: 372
    edited April 2007
    gvg45 wrote: »
    Thank you. I guessed right when I hooked them up.
