Surround or SB?
Sansui
My Dinon 887 amp supports 7.1 but I'm using a 5.1 speaker setup. Should I have my back speakers hooked up to the "Surround" or "Surround Back" speaker connections? Does it matter?
Be gentle, I'm new to all this...
The mind blowing speed of the BRAIN TRAIN...
Post edited by Sansui on
i like it. Most movie are only 5.1.engtaz
5.1 set-up on a 7.1 AVR usually calls for surrounds to be hooked up to the "surround" connections. 'Surround Back" is usually used for either multi-room or the addition 2 channels if you decide to go 7.1
Thank you. I guessed right when I hooked them up.5.1 set-up on a 7.1 AVR usually calls for surrounds to be hooked up to the "surround" connections. 'Surround Back" is usually used for either multi-room or the addition 2 channels if you decide to go 7.1Be gentle, I'm new to all this...
