Monitor 10 upgrade
  • Rivrrat
    Rivrrat Posts: 2,101
    edited April 2007
    Now that I'm planning to do this for my first time on my next vacation next month. Should I just copy the existing crossover with better components, is there a formula that I should know about, or is this just trial and error?
    My equipment sig felt inadequate and deleted itself.
    heiney9 Posts: 25,509
    edited April 2007
    Rivrrat wrote: »
    Do you have the peerless tweeter or the sl2000? Most likely follow the schematic or use the same value parts on the current x-over, then evaluate and decide if you want to tweak the values furthur. I know it's a PITA to pull things and mess with it more than once but if you are going to experiment beyond the stock design values that's what it takes.
  • Rivrrat
    edited April 2007
    I have sl2000's. I may change them out, but I don't know for sure yet.
    I guess if I have to mess with it, so be it. Unfortunately for me, this hobby in a way is not a lot different from what I do for a living, and I really just want it to be magically done after playing with stuff at work all day.:rolleyes:
    I think, I'll just go ahead and match valuse and see how it goes. I see an order for Solen's and Mills in my near future.
