Budget speaker cable - Python2 12 AWG?
ViperZ
ViperZ Posts: 2,046
Can anyone let me know what they think about Python2 speaker cable?
http://www.pacificcable.com/Picture_Page.asp?DataName=255-513CL
I found 100' for $50 shipped, and that's pretty much all I can afford.
I think 100 feet will be enough to wire my 5-speaker home theater in the new condo.
Any other recommendations for similarly priced budget cables? Thanks!
[EDIT]Monoprice 12 AWG cable. LOOKS the same as Python2, oxygen-free, PVC insulation, etc... WHAT'S THE DIFFERENCE??? [/EDIT]
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023901&p_id=2789&style=&seq=1&format=4#feedback
[EDIT #2]Also need Banana terminations. Monoprice has screw-on banana connectors for ~1.56 per PAIR (if bought 8+ or somethhing - I need 10 pairs anyway). ARE THESE ANY GOOD?? [/EDIT]
Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
Post edited by ViperZ on
  • Cursed1
    Cursed1 Posts: 66
    edited April 2007
    Sounds like a pretty good deal to me.
  • ViperZ
    ViperZ Posts: 2,046
    edited April 2007
    There are so many cheaper speaker wires out there - Python (slightly cheaper than Python2), Belkin, Monster, Phoenix...
    Usually these wires are around 16 AWG, but Python2 is 12 AWG (and for extra $5 per 100' I can get 10 AWG, but that would be an overkill for my wire runs).
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • louthewiz
    louthewiz Posts: 581
    edited April 2007
    Even "Pyramid" makes a 100 foot roll of #12 for 25 bucks.
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
  • daboyz
    daboyz Posts: 5,207
    edited April 2007
    Try BlueJeans Cable. The Belden 5000 is $.38 a foot,12 AWG, in wall rated and easy to work with. Excellent cable IMHO.
    Dave
  • ViperZ
    ViperZ Posts: 2,046
    edited April 2007
    Yeah, that looks great too... $38+~$6 for shipping is within my budget...
    Still can't figure out what in the world is the difference??? All of these cables are same AWG, same conductor material, same insulation, same construction (stranded, etc.)...
    [EDIT]Just wanted to add a link to BlueJeans Belden cables. 0.38-0.40/foot is not bad, considering how much you guys love these wires: http://bluejeanscable.com/store/speaker/index.htm [/EDIT]
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • ViperZ
    ViperZ Posts: 2,046
    edited April 2007
    Umm... Black or white magic, I don't care... I want to read some reviews... and not for $1000/ft cables, just decent $0.5-0.75/ft ones... (being electrical engineer, I'll understand).
    I have read some scientific and some audio articles...
    This one is very simple and good: http://www.roger-russell.com/wire/wire.htm . Just shows how subjective everything is, and as long as you use good wire (constant resistance (I wouldn't even call it impedance), stay within approximate AWG. vs length ratio), you shouldn't have problems..
    Hopefully I convinced myself... :confused:
    [edit]I will expect the difference, although minor, when I'll install one of these 12 AWG instead of my current (very cheap, picked up in some electronics store when really needed) 16 AWG wires... we'll see next month :) [/edit]
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • daboyz
    daboyz Posts: 5,207
    edited April 2007
    Do the Belden, I'm running it and I wired my brothers whole house with it. For a budget price it's a steal.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited April 2007
    daboyz wrote: »
    Dave
    +1
    I used this wire myself for my rear surround speakers. Used it in my attic, the walls. Used 600' of it. :) Well I used it for my whole house audio speaker system also.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • engtaz
    engtaz Posts: 7,674
    edited April 2007
    ViperZ wrote: »
    [EDIT #2]Also need Banana terminations. Monoprice has screw-on banana connectors for ~1.56 per PAIR (if bought 8+ or something - I need 10 pairs anyway). ARE THESE ANY GOOD?? [/EDIT]
    I have the solder on (but solder not needed) connectors from monoprice and I like them a lot. I like monoprice cables.
    engtaz
    engtaz
  • ViperZ
    ViperZ Posts: 2,046
    edited April 2007
    After checking out Belden 12 AWG cable ($44 shipped) vs. 12 AWG Monoprice cable ($35 shipped), I think it's worth trying Belden. The only thing that is holding me now is that Monoprice's banana plugs are 1/2 price of the ones sold on Blue Jeans site, and I'd prefer to buy it all together.
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • vonnie123
    vonnie123 Posts: 326
    edited April 2007
    Considering your log in, Viper AV cables came to mind. The site is cut in below. I bought a set of the Studio Pro Speaker Cables off of ebay about six months ago for about $60. They are well built, nice sounding cables. I have used Monster, and Belkin cables as well, and these are really nice, especially at the ebay price. Good luck.
    http://www.viperav.com/
