do different rca connectors make difference in sound?
marvda1
marvda1 Posts: 4,942
edited February 2008 in 2 Channel Audio
let me pose a question. if you have five identical lengths of the same cable but terminate them with different connectors, say generic good quality rca's, vampire, cardas, wbt, and bullet plugs, will there be a noticable improvement(difference) in sound to justify the various levels of increase in price?
Puritan PSM156
Post edited by marvda1 on
  • Early B.
    Early B. Posts: 7,900
    edited April 2007
    I've used bullet plugs and WBT's with Kimber Hero interconnects and the bullet plugs were better. I had to listen very critically to discern the differences, though.
    "God grooves with tubes."
  • marvda1
    edited April 2007
    Puritan PSM156
  • pearsall001
    pearsall001 Posts: 5,249
    edited April 2007
    I wouldn't fret over it. Some might be better than others (subjective) but It's not a big concern in my book. As long as the connection is tight & doesn't come loose, to me that's good enough.
  • Emlyn
    Emlyn Posts: 4,650
    edited April 2007
    marvda1 wrote: »
    Using a Sony Playstation One as a reference audiophile CD player? That's a new one to me!
  • Gaara
    Gaara Posts: 2,415
    edited April 2007
    I found that odd as well, I respect 6moons a lot and love their reviews, but they do a lot of odd things.
    I like the bullet plugs a lot but they are to flimsy IMO. I have had issues with buzzing and humming in my system, and they all stem from the bullet plugs breaking. Given recently I have had a lot of changes in my system, so lots of unhooking and rehooking, but the only cables I have that have ever broken are ones with bullet plugs.
    Jared
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited April 2007
    Gaara wrote: »
    Jared
    The "low mass" (read:PLASTIC) body has a lot to do with that....I have a set of bayonets on my home-brew cables and I broke every damn one of them taking them apart to solder them up...Thank god for super glue and heat shrink I guess....They were super easy to solder and sound great though, so I can't really complain......I personally think they are WAY overpriced though.
  • ben62670
    ben62670 Posts: 15,969
    edited April 2007
    I agree. If its gold plated, and fits nice and tight, easy to work with it is good in my book.
    Ben
  • fredv
    fredv Posts: 923
    edited April 2007
    Ditto.
    -fredv-
  • marvda1
    edited April 2007
    i sent the author of the comparison an email asking about the sony playstation.
    in his comparison the connector that won was less expensive than the bullet plugs.
    Puritan PSM156
  • marvda1
    edited April 2007
    ben62670 wrote: »
    so does that make locking connectors the way to go?
    marvin
    Puritan PSM156
  • marvda1
    edited April 2007
    here is the reviewer's reply to my inquiry about the playstation one.
    "Hi Marvin,
    The PS1 is an audio underground favorite. It's performance has exceeded the performance of digital front ends valued up to $8K here at my place. In fact I haven't heard anything that bests it yet. You have to get the SCPH-1001 model of the PS1, and as long as you keep it warmed up and never turn it off you'll get excellent performance.
    Best,
    Jeff"
    Puritan PSM156
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2007
    Bullet plugs just stink, locking RCA's are the bees knees. A cable is only as good as the termination.
  • Serendipity
    Serendipity Posts: 6,975
    marvda1 wrote: »
    "Hi Marvin,
    Best,
    Jeff"
    So the Playstation One is actually a high-end CDP? If its true, it would be one of the greatest "hidden gems" in the audio world!
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Midnite Mick
    Midnite Mick Posts: 1,591
    I think the ends have as much effect if not more than the wire. I love the WBT Nexgens.
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
    F1nut Posts: 51,709
    Locking RCA's can't be beat, IMO.
  • ben62670
    I'll have to ask Bill.
    Ben
