Question About Mounting a Flat Panel Monitor
jgido759
Just looking for some opinion/feedback on mounting a SMALL 20" flat panel monitor (weight approx 14lbs.) in our bedroom. I purchased a mounting bracket for mounting to a single stud (bracket weight is < 4lbs). The only problem is that the wall space available for mounting does not contain a stud in the correct location (center of the wall). It is a small section of wall space between a doorway and a closet approx. 24" across and, unfortunately, the only available space.
Would it be possible to use 2 "molly" screws (NOT plastic anchors) through the bracket & drywall. Total weight would be < 20lbs.
Thanks in advance.
Thanks in advance.
Oh, you hate your job? Why didn't you say so? There's a support
group for that. It's called EVERYBODY, and they meet at the bar.
-Drew Carey
There is a very fine line between "hobby" and "mental illness."
-Unknown
My DVD Collection
-Drew Carey
-Unknown
My DVD Collection
Post edited by jgido759 on
I think that would work. I've hung things more than 20lbs in drywall using some decent plastic anchors w/o any issues. . . however, it wasn't a $500 breakable object so I wasn't overly concerned.
I would just ask someone for help at your neighborhood hardware store, Home Depot, or Lowe's. Or, someone will probably chime in here with a better response. . . eventually.
Good luck! If you have 8 deep anchored screws, I think you should be okay.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
This looks helpful. Love google.
http://www.naturalhandyman.com/iip/inffastener/infanchor/infanchor.htmlStereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
For the size of that screen I say it's ok not to use a stud, but I wouldn't use anything other then a Toggle Bolt.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Thanks, guys. My terminology was slightly off in saying "molly" but actually meaning "toggle".
Looks like 2 toggles will work based on the link provided by AndyGwis.Oh, you hate your job? Why didn't you say so? There's a support
-Drew Carey
-Unknown
My DVD Collection -
disneyjoe7 wrote: »For the size of that screen I say it's ok not to use a stud, but I wouldn't use anything other then a Toggle Bolt.
+2
Get a BIG one. The problem with a tv mount is that the force of the TV will want to pull the top toggle out of the wall and push the bottom mount down through the wall. If the mount has an extendable arm it will need to be stud mounted. The further from the wall the greater the pull-out force on the top bolt. -
daniel_paul_ wrote: »If the mount has an extendable arm it will need to be stud mounted.
No extendable arm, flush-mount only.
OmniMount QM100FOh, you hate your job? Why didn't you say so? There's a support
-Drew Carey
-Unknown
My DVD Collection -
Use Hilti anchors.
