SDA-1C's...which tweeters are these?
avguytx
avguytx Posts: 1,628
edited April 2007 in Speakers
From what I've read, the SDA-1C comes with 4) SL2000 tweeters, correct? Which ones are these in the ones pictured? Aren't they some of the new type? RD0194's? I can't remember which ones are compatible for swapping out with the 2000.
Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
Post edited by avguytx on
    F1nut Posts: 51,746
    edited April 2007
    Those are SL3000's and are not suppose to be in those speakers.
  • ben62670
    ben62670 Posts: 15,969
    edited April 2007
    Pull one of the tweets, and it should be labeled on the back. As F1 has stated they do look like SL3000's with the dark metallic look.
    Ben
  • danger boy
    danger boy Posts: 15,722
    edited April 2007
    why is that? What should it be, the SL2500?
    PolkFest 2012, who's going>?
    F1nut Posts: 51,746
    edited April 2007
    The only SDA speakers that were designed to use the SL3000 tweeters are the 1.2TL, 2.3TL and 3.1TL. The TL stands for tri-laminate. The 1C's were designed to use the SL2000, none of the SDA's ever used the SL2500.
    No need to pull those tweeters in the picture, I guarantee they are SL3000's.
  • ben62670
    edited April 2007
    danger boy wrote: »
    SL2000's, but you know how Polk was back then. They probally slipped a couple out the door with 2500's in them:D
    I type to slow. F1 beat me to it :-)
    Ben
  • danger boy
    edited April 2007
    how did it happen do you think then? that's very odd.. and it's not like just one of the tweeters is wrong.. all four of them are.. which seems strange to me.
  • george daniel
    george daniel Posts: 12,096
    edited April 2007
    Jesse is "da man" :) Like he said,now would be a good time to get the rdo replacements,,or pick up some used sl 2000's here,I'm sur that they are some lying around,,if not I'll have some available real soon. SDA 1C's are my favorites--have fun:)
    F1nut Posts: 51,746
    edited April 2007
    Al, the most common reason would be that some folks don't know WTF they are doing.
  • george daniel
    edited April 2007
    Sell the sl-3000's and put the money towards the rdo's,and you are good to go
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    RD0194's have a black dome.
    engtaz
    engtaz
  • avguytx
    edited April 2007
    That's kind of what I thought, too. Somehow they ended up with (what I thought was) the SL3000's. I'll just put them on Ebay and buy the RD0194's since that's the recommended upgrade, anyway. I'll pick them up later this week so I'm excited. Maybe I won't be travelling long enough to listen to them!
    Oh...the second Carver M-1.0t that I had bought from a friend in IL never made it out of the terminal. Tracking shows it dropped off, scanned, and then no movement for 10 days. Pisses me off...that's the first trouble I've had with Fedex. It was being shipped directly to Carver Repair in WA. Oh well...
