WBT 0101 RCA Plugs, high end connectors!
hearingimpared
Brand new, never opened WBT 0101 RCA Plugs. These are the model that require soldering. I have these on many of the cables in my 2 ch rig. They have easy to use AND REMEMBER (turn the black coller clockwise to lossen, counter-clockwise to lock) locking collets which make a tenacious grip on the RCA jack it is connected to.
Here is what WBT writes about their product:
That cross slotted center pin makes intimate contact with the internal jack.
These are the real deal, very heavy for their size.
I've seen these sold from $32 each to $99 dollars/pr and up to $134 for the kit which as far as I can tell just gives you some silver soldier. The ones I am selling are not color coded.
Here are some links to check them out;
http://java.audioasylum.com/ca/ca.jtp?ca=3773
http://www.takefiveaudio.com/PDF/WBT%200101.PDF
http://www.wbtusa.com/wbt0101.html
http://www.mr-cable.com/rca%20Male.htm
http://www.ramelectronics.net/html/connectors.html#wbt0101
http://www.musicdirect.com/products/detail.asp?sku=AWBT0101
Price: $32 per pair, + $3 ship'g
Top-quality plug with high copper content. Ultra fine machining. Unique multi-layer plating process with a final plating of 24k gold. Patented WBT™ mechanism provides both adjustment and locking functions. Barrel finished in polished ruthenium. Cross slotted center pin for perfect fit. Teflon™ insulation. Strain relief captured with Torx™ screw. Cable diameter, 9.1 to 11.3 mm / 0.358 to 0.445".
Post edited by hearingimpared on
How many pair(s) do you have?I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
This is an EXCELLENT DIY choice for terminations. I picked up a couple pairs for my goody box.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
MillerLiteScott wrote: »How many pair(s) do you have?
11 1/2 . -
A new member brought to my attention that there are some knock-offs of this product. These are not knock-offs, I wouldn't sell knock-offs without stating so.
They have the WBT logo and the 0101 model numbers on them as well as where they were manufactured, Germany.
I have used these at one time to make several really high end cables, as a matter of fact I still use them between my preamp & one set of amps as they are great for bass reproduction. -
Two pair sold to Blownrx7. Thanks Joe. 9 1/2 pairs left.
MO received Blownrx7, thanks. Will ship tomorrow.
bump
bump
One pair left!!!
Throw them in the river as a time capsule.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
bump
PM sent
Edit
BTW I have worked with these. You need to scuff the connectors where you are going to be soldering them, and heat them up pretty good to tin them before you actually solder the wire to the. Otherwise you will have a poor connection. I used a high heat gun, not a typical soldering iron.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Three pairs left.
bump
Bump
What is left in your stock pile kind sir?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I have three pair of new ones. I also have some used ones that are still connected to cable; we can talk about a price for them if you'd like.
bump
