WBT 0101 RCA Plugs, high end connectors!
hearingimpared
hearingimpared Posts: 21,136
edited November 2007 in For Sale (FS) Classifieds
Brand new, never opened WBT 0101 RCA Plugs. These are the model that require soldering. I have these on many of the cables in my 2 ch rig. They have easy to use AND REMEMBER (turn the black coller clockwise to lossen, counter-clockwise to lock) locking collets which make a tenacious grip on the RCA jack it is connected to.
Here is what WBT writes about their product:
Top-quality plug with high copper content. Ultra fine machining. Unique multi-layer plating process with a final plating of 24k gold. Patented WBT™ mechanism provides both adjustment and locking functions. Barrel finished in polished ruthenium. Cross slotted center pin for perfect fit. Teflon™ insulation. Strain relief captured with Torx™ screw. Cable diameter, 9.1 to 11.3 mm / 0.358 to 0.445".
That cross slotted center pin makes intimate contact with the internal jack.
These are the real deal, very heavy for their size.
I've seen these sold from $32 each to $99 dollars/pr and up to $134 for the kit which as far as I can tell just gives you some silver soldier. The ones I am selling are not color coded.
Here are some links to check them out;
http://java.audioasylum.com/ca/ca.jtp?ca=3773
http://www.takefiveaudio.com/PDF/WBT%200101.PDF
http://www.wbtusa.com/wbt0101.html
http://www.mr-cable.com/rca%20Male.htm
http://www.ramelectronics.net/html/connectors.html#wbt0101
http://www.musicdirect.com/products/detail.asp?sku=AWBT0101
Price: $32 per pair, + $3 ship'g
Post edited by hearingimpared on
