Please Help! Need interconnect cable.
drock69
I just acquired some SDA-CRS's. I need the interconnect cable. If anyone has one let me know. Thanks.
Post edited by drock69 on
You could order one from Polk or make one from materials found at Home Depot.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
dorokusai wrote:You could order one from Polk or make one from materials found at Home Depot.
Do you have info on how to make one from home depot? and exactly what does this do for me? -
Welcome to Club Polk
Do you have the pin blade connections, or blade blade?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
ben62670 wrote:Welcome to Club Polk
I have the pin blade. one is a little jack and flat blade. -
You have SDA CRS+'s, not SDA CRS's. Polk no longer sells the pin/blade cable, but you can make one.
Since you aren't sure what the cable does, I'd suggest you ask Polk to mail you a copy of the owners manual before using the speakers.Political Correctness'.........defined
President of Club Polk -
I have the manual(s) in pdf, do you want it? Let me know here and I will PM you my email address.
BTW welcome to the club. -
You could buy a ready made cable and install new jacks in speakers as below. Cable may be better than stock as is a larger wire gauge.
Get a Neutrik Speakon speaker cable 10, 12 or 14 Gauge with connectors installed. Polk factory cable is 16 Gauge. (20 foot pair 14 AWG Copper on eBay $20 buy now price) These usually come with 4 pole (4 pin) connectors. I would connect one conductor to 2 pins, providing twice the surface contact area. (But do not use this cable as a "normal' cable with an amp or other speakers using this type cable connector.) Parts Express has a "kit" you can use to change the connectors to angled connectors without disconnecting the wire. (Less than $2)
You will have to install and wire matching jacks in the cabinet which require a 1" hole drilled in cabinet. (Verify hole size before drilling!) Connect each wire to 2 pins corresponding to speaker cable pins. Two type Jacks available, round or square plate. ($6-$7 pair on eBay) New model jacks have screw terminals. You could cut wires from original Interconnect Jack and crimp ring terminals to the wires coming from crossover to fasten to new jack. These jacks are airtight, meaning you do not have to cover the rear with hot glue to seal air leaks. You will need to use a gasket or foam tape behind the plate to seal it when screw mounted to the outside of cabinet.
You can get materials at any Pro Music Store, eBay, or Parts Express.Mains; SDA 1.2TL Silk Domes, upgraded xover, biamped w/DBX BX1 200wpc
Pre-amp: DBX CX1
Center: CS1000p Rear Surr.; f/x1000
Parasound HCA-1205A amp; Center & rear
Sub: SVS PB12-Ultra
DVD: Denon 3910
Tuner, FM: Onkyo Integra T-9090II
Cassette: Onkyo Integra TA-2090
VCRs: JVC HD4000U digital, HRS8000U SVHS
Signal Processing: DBX; 10/20 EQ, SNR-1, 120X-DS, 3BX-DS, DAV-600G Router, Onkyo EQ-35
Conditioning: Monster AVS2000, HTS5100MKII
