Please Help! Need interconnect cable.
drock69
drock69 Posts: 3
edited March 2007 in Vintage Speakers
I just acquired some SDA-CRS's. I need the interconnect cable. If anyone has one let me know. Thanks.
Post edited by drock69 on
  • dorokusai
    dorokusai Posts: 25,625
    edited March 2007
    You could order one from Polk or make one from materials found at Home Depot.
  • drock69
    drock69 Posts: 3
    edited March 2007
    Do you have info on how to make one from home depot? and exactly what does this do for me?
  • ben62670
    ben62670 Posts: 15,969
    edited March 2007
    Welcome to Club Polk
    Do you have the pin blade connections, or blade blade?
    Ben
  • drock69
    drock69 Posts: 3
    edited March 2007
    I have the pin blade. one is a little jack and flat blade.
    F1nut Posts: 52,243
    edited March 2007
    You have SDA CRS+'s, not SDA CRS's. Polk no longer sells the pin/blade cable, but you can make one.
    Since you aren't sure what the cable does, I'd suggest you ask Polk to mail you a copy of the owners manual before using the speakers.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2007
    I have the manual(s) in pdf, do you want it? Let me know here and I will PM you my email address.
    BTW welcome to the club.
  • RichCanDo
    RichCanDo Posts: 177
    edited March 2007
    You could buy a ready made cable and install new jacks in speakers as below. Cable may be better than stock as is a larger wire gauge.
    Get a Neutrik Speakon speaker cable 10, 12 or 14 Gauge with connectors installed. Polk factory cable is 16 Gauge. (20 foot pair 14 AWG Copper on eBay $20 buy now price) These usually come with 4 pole (4 pin) connectors. I would connect one conductor to 2 pins, providing twice the surface contact area. (But do not use this cable as a "normal' cable with an amp or other speakers using this type cable connector.) Parts Express has a "kit" you can use to change the connectors to angled connectors without disconnecting the wire. (Less than $2)
    You will have to install and wire matching jacks in the cabinet which require a 1" hole drilled in cabinet. (Verify hole size before drilling!) Connect each wire to 2 pins corresponding to speaker cable pins. Two type Jacks available, round or square plate. ($6-$7 pair on eBay) New model jacks have screw terminals. You could cut wires from original Interconnect Jack and crimp ring terminals to the wires coming from crossover to fasten to new jack. These jacks are airtight, meaning you do not have to cover the rear with hot glue to seal air leaks. You will need to use a gasket or foam tape behind the plate to seal it when screw mounted to the outside of cabinet.
    You can get materials at any Pro Music Store, eBay, or Parts Express.
    Mains; SDA 1.2TL Silk Domes, upgraded xover, biamped w/DBX BX1 200wpc
    Pre-amp: DBX CX1
    Center: CS1000p Rear Surr.; f/x1000
    Parasound HCA-1205A amp; Center & rear
    Sub: SVS PB12-Ultra
    DVD: Denon 3910
    Tuner, FM: Onkyo Integra T-9090II
    Cassette: Onkyo Integra TA-2090
    VCRs: JVC HD4000U digital, HRS8000U SVHS
    Signal Processing: DBX; 10/20 EQ, SNR-1, 120X-DS, 3BX-DS, DAV-600G Router, Onkyo EQ-35
    Conditioning: Monster AVS2000, HTS5100MKII
