Plasma wall mount cable management?
Wider is better. And like DL said get the tilt, or you'll probably have to take the set down everytime you need to make a connection.
In a worst case scenario, you can do what a friend of mine did. attach the mount to plywood and then attach the plywood to the wall. Mt wife wants to move ours a bit due to new furniture, and I may end up having to do that.My equipment sig felt inadequate and deleted itself. -
check out www.superbhometheater.comEverytime I think I'm out, THEY PULL ME BACK IN!!!!!!
Polk 70's,40,30's
Velo DLS 3500 Sub
JVC 61" HD-ILA
Sony DA4ES AVR
Oppo 981 DVD
Sony CDP-CX235 CD
Signal Bi-wires
AR ProII IC's -
Maurice, you like that better then the above solution? I guess you're not handy with a hole saw? I was talking about in-wall wiring.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
