Plasma wall mount cable management?
  • Rivrrat
    Rivrrat Posts: 2,101
    edited March 2007
    Wider is better. And like DL said get the tilt, or you'll probably have to take the set down everytime you need to make a connection.
    In a worst case scenario, you can do what a friend of mine did. attach the mount to plywood and then attach the plywood to the wall. Mt wife wants to move ours a bit due to new furniture, and I may end up having to do that.
    My equipment sig felt inadequate and deleted itself.
  • Maurice
    Maurice Posts: 517
    edited March 2007
    Everytime I think I'm out, THEY PULL ME BACK IN!!!!!!
    Polk 70's,40,30's
    Velo DLS 3500 Sub
    JVC 61" HD-ILA
    Sony DA4ES AVR
    Oppo 981 DVD
    Sony CDP-CX235 CD
    Signal Bi-wires
    AR ProII IC's
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited March 2007
    Maurice, you like that better then the above solution? I guess you're not handy with a hole saw? I was talking about in-wall wiring.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
