SDA-SRS inductors
ben62670
ben62670 Posts: 15,969
edited March 2007 in Vintage Speakers
I am currently building some SDA-SRS speakers, and I wanted to use some after market inductors (low resistance) I don't have the original for the mids. I am presently using SDA2a inductors which have the same inductance, but are very light gage. Does low resistance inductors have any adverse affect on the SDA effect? I also wanted to use a low Resistance inductor for the dim array. I think stock is 16 MH. My concern is with the signal path I think the inductor prevents near dead short via interconnect cable.
Thanks Ben
Ben
Post edited by ben62670 on
  • ben62670
    edited March 2007
    bump
    Ben
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2007
    ben62670 wrote:
    bump
    Do you still need the inside dimensions?. . . don't forget the SRS are different from the 1.2 TLs.
  • ben62670
    edited March 2007
    Yes please, and I know.:)
    Ben
    Ben
  • hearingimpared
    edited March 2007
    Ben
    Looks like a go Saturday, I'll keep you apprised.
