Interconnects or Speaker Cables or Both
  • ncmarine
    ncmarine Posts: 31
    edited March 2007
    I have worked in electronics for over 12 years now, 10 of those years in a calibration lab. I'll say that when testing RF or microwave cables/equipment we check the output of every connection. This way you can properly determine where losses are coming from in a system.
    That being said, since ICs are connected closer to the production source of the original signal, then they have the greatest ability to affect the total system. However, if your speaker cable isn't as good of a conductor and resistant to standing waves, then you defeat the purpose of having quality ICs. In the lab, we have always used similar cables (target being <1db loss per meter) for all connections in order to create a standard.
    In audio applications, since the speakers are the output device, then I'd say the signal being output is only as good as your weakest link..
    ncmarine
    60" Sony SXRD
    Denon AVR-2807
    Adcom GFA 555Mk-II
    Outlaw M2200 x 3
    Fronts - RTi8s
    Center - CSi5
    Sides - Rti8s
    Rears - RTi6s
    Sub - PSW505
    DVD - Samsung HD860
    Playstation 3
    XBox 360
    Monster HTS2600
  • pearsall001
    pearsall001 Posts: 5,295
    edited March 2007
    I have ask Antny, Phil, Dave, or Lou . . . I use it on my right ear, the one that has hearing loss.
    Yep, he sure did. Don't know if will qualify for a patent though. Oh, & Joe looks so cool wearing it. Just hope he never runs out of rubber bands!!!!:D
    Are we still on for tomorrow? It's not too bad out there. Roads are a bit sloppy but nothing major.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2007
    I'll email you about tomorrow.
