External DAC or not with Denon 3910
joeparaski
joeparaski Posts: 1,865
I now own a Denon 3910 and I've got an MSB Link Dac III with seperate power base that is arriving in a couple of days. Is the DAC in the MSB better than the built-in DAC in the3910? Aside from a listening test, specification-wise, which DAC is better?
3910 owners....do you use a seperate DAC?
Joe
Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
Post edited by joeparaski on
  • steveinaz
    steveinaz Posts: 19,545
    edited March 2007
    It'll probably be a close competition, more of a difference in "character" of the sound. I run a Denon 2910, and have run it through my Benchmark DAC for a time. Through the DAC the 2910 was a little more articulate, deeper soundstage, and tighter/cleaner bass. The 2910 on it's own was warmer sounding, but bass was a little flabby and treble not nearly as grain-free.
    I realize this isn't the direct comparison you were looking for, but I think it demonstrates that it will come down to A/B'ing the setup and see which tonal character you prefer----I suspect that if you like more articulation, you'll prefer the external DAC; if you like a warmer/richer sound, you'll prefer the 3910 stand-alone.
  • cstpeter
    cstpeter Posts: 387
    edited March 2007
    I experienced a big improvement going with the PS Audio DAC out of a Denon 2900 (the older 3910). But like Steve said, this isn't a direct comparison and it will come down to a direct A/B with your gear.
    Von Schweikert VR4-jr
    Valve Audio Predator
    Denon DVD-2900
    PS Audio Digital Link III w/Cullen Level IV Mods
    Pro-Ject Xpression w/Blue Point No. 2
    Graham Slee Special Edition 2
    PS Audio UPC-200
  • John K.
    John K. Posts: 822
    edited March 2007
    Joe, as shown in this table of receiver and player components, the 3910 uses the DSD1796 DAC made by Texas Instruments in their Burr-Brown Division. If you click on DSD1796 you'll get brief specs and other info(you can then click there for the full data sheet). From the specs, including a 123dB dynamic range, it's clear that the capabilities of the 1796 exceed the requirements of all material which might be played, and no other DAC can provide any audible improvement . You'll also note the price, and typically Denon would be able to get these in very large quantities for about $2 each.
    So, as is commonly the case these days, the particular DAC which the manufacturer has specified can more than meet all design requirements, and should be a non-issue for the audio consumer. If there's any difference you can rest assured that the DAC has nothing to do with it.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited March 2007
    Anti Hi-Fi Audio Insurgent sighting.
    RT1
  • Lowell_M
    Lowell_M Posts: 1,660
    edited March 2007
    .... As I proudly put on my " "Cables don't matter" - John K " T-shirt.
    I may be ordering a new shirt that says.. "DAC's don't mean smack"
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • cstpeter
    cstpeter Posts: 387
    edited March 2007
    Just curious: How does this post help Joe? Are you actually saying an external DAC won't make a difference (never mind the output stage, power supply, etc.)? Or are you just trying to make a point?
    Joe, I recommned you try out an external DAC. As I posted, I noticed a huge difference.
    Denon DVD-2900
    PS Audio UPC-200
  • Serendipity
    Serendipity Posts: 6,975
    edited March 2007
    I would try an external DAC, but be warned that the Denon's DACs might even be better.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • steveinaz
    edited March 2007
    Agree with JohnK, just buy a Sony walkman to use as a source and be done with it---bits is bits, right? sheeeesh.
    It's not just the DAC's, it's the implementation and final analog output stage. It's like saying all 350 cubic inch V-8's have the same horsepower---non-sense.
    heiney9 Posts: 25,441
    edited March 2007
    first part................NM, no use blowing a gasket over this. :rolleyes:
    Joe, let your ears decide if you can 1) hear a difference 2) if the difference you hear is what you prefer over what you have 3) DON'T EVER listen to JohnK and his wheel barrow full of manure.
    To JohnK. read my sig and then re-read it again. I appreciate the subtleties in music and audio you don't even acknowledge they exsist.
    Good day to you!!!!
    edited March 2007
    Not likely for the units discussed here so far. The Denon probably sounds pretty good on it's own, but a well designed and implemented outboard Dac is usually better or atleast different in good ways, one has to decide with their own ears if it suits them. Some people don't like as much "truth" in their music or like things a bit bloated and bass heavy. Generally a well designed dac will tighten up the bass, improve the soundstage depth and realism, add some air around the recording (which is already there) and generally make things sound more realistic. That is unless the recording is lacking, which so many pop type recording are.
    The biggest thing I noticed was EVERY single cd I played sounded different, good and bad. Before adding the dac many things just sounded the same, sure I heard differences between crappy recordings and stellar recordings, but I was missing the subtle nuances of the recordings (again good and bad). Now every single recording stands on it's own and has it's own characteristics for good and for bad.
  • Ricardo
    Ricardo Posts: 10,636
    edited March 2007
    Finally...a definition for those orgasmic milliseconds when you experience what no one else in the room seem to hear, but makes this whole damn expensive hobby worth every penny.....
    SOPA
  • rskarvan
    rskarvan Posts: 2,374
    edited March 2007
    JohnK, when it comes to how good music sounds, you can rest assured that the DAC has EVERYTHING to do with it. Afterall, everything before the DAC is just software. Everything after the DAC is just signal processing. The DAC is the only component that actually generates the music that we all appreciate.
  • dkg999
    dkg999 Posts: 5,647
    edited March 2007
    Good to know that when John K shows up I can serve him Boone's Farm wine, because it certainly meets all the necessary design requirements ;)
    DKG999
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited March 2007
    I wouldn't have thought this but have been leaning this way. Makes me wonder why buy high end players at all. Seems to me high quality can be obtained less expensively with transport and DAC.
    Heiney.....love the sig. I didn't notice it before
    Thanks,
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
    tonyb Posts: 33,072
    edited March 2007
    RT1
    Man...I love this place :D
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2007
    Oppo HD 970, digital cable out, w/digital cable to Timbre DAC, Timbre DAC to Spectral preamp, preamp to speakers via bi-amping, brings a smile to my face EVERY TIME!!!
    It's all in the DAC man, it's all in the DAC. . .and. . . .it's all good brother, it's all good!
    H9 love you sig.
  • hearingimpared
    edited March 2007
    Me too!!!
  • Midnite Mick
    edited March 2007
    However, wouldn't the one spec that a DAC couldn't improve is the dynamic range? Just asking as I thought that this was the limitation of the Oppo as a source from other people's comments. I guess I could check but I am lazy :D
    Thanks,
    Mike
    Consonance cd120T
    Usher CP 6311
  • joeparaski
    edited March 2007
    Thank you for your thoughts on this subject guys. I checked UPS tracking and my MSB Link DAC III is now in Syracuse. I've got a day off tomorrow, so if it comes in, I'll set it up with the Denon and see how it sounds before and after and with and without the DAC.
    I wish I had more time to play with this stuff. I'm still doing those crazy hours. This is freakin' weird, I work 80 hours to pay for audio gear that I can't get to hear much because I work 80 hours.
    Joe
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2007
    I don't use a DAC with the 3910 but then again its in the HT. I have never had any personal interest in DAC's and have heard many of them. I think they're great for when you have a POS source but its not a list topper for me.
  • reeltrouble1
    edited March 2007
    There certainly is much more to consider than the just the conversion. Each interface within the chain can only degrade the signal or not.
    RT1
  • hearingimpared
    edited March 2007
    Thanks,
    Mike
    The only thing I use from the Oppo is its transport which seems to be pretty good. The question is, will it stay consistant and for how long? Also don't forget I use that Marigo mat.
  • hearingimpared
    edited March 2007
    Joe
    Does this ring a bell from a movie . . . CATCHA TWENTY TWOA, CATCHA TWENTY TWOA!
  • Systems
    Systems Posts: 14,873
    edited March 2007
    Yep,what steve said.
    Testing
    Testing
    Testing
    SCompRacer Posts: 9,112
    edited March 2007
    dkg999 wrote:
    .....I can serve him Boone's Farm wine,...
    Guess it will have to be Boone's cause they don't make Ripple no more.
    I don't need no diamond ring
    I don't need no Cadillac car
    Just want to drink my Ripple wine
    Down in the Lightnin' Bar
  • venomclan
    venomclan Posts: 2,467
    edited March 2007
    Let us know your findings Joe. I have had good success with a Denon 2900 and the Bel Canto Dac 1.1. The Dac added a little more nuance and air to the music. Bass tightened up also. Less smear. I find that the Dac makes much more of a difference than the transport. imho.
    Venom
  • hearingimpared
    edited March 2007
    Venom
    I wanted to add one more thing. My Timbre DAC brings CDs one giant step closer to sounding like vinyl.:)
  • steveinaz
    edited March 2007
    The Bel Canto is an excellent DAC, I-Sig & I A/B'd a Bel Canto against my Benchmark and we struggled to hear any difference between the two. We used the same transport (CEC) with the coax out to the Bel Canto and the AES/EBU out for the Benchmark. Luckily output levels appeared to be perfectly matched, so we just used the remote on my pre to switch between them.
  • cstpeter
    cstpeter Posts: 387
    edited March 2007
    Word. The first thing I thought when I heard my DAC was, "This kinda sounds like my record player." Definitely a good thing.
    Denon DVD-2900
    PS Audio UPC-200
  • venomclan
    edited March 2007
    Steve, did you a/b the Bel Canto Dac 1.1, or the Dac 2?
    Venom
