HDCD Hookup
PolkFan1
PolkFan1 Posts: 130
I am planning on buying a cd player that has HDCD compatibility. The Denon DCM 390. I am only going to be using the analog connections to hook up the cd player to my stereo 2 ch. receiver.(The red and whites). Will I still be able to obtain the HDCD format from the cd player?
Post edited by PolkFan1 on
  • ledhed
    ledhed Posts: 1,088
    edited March 2007
    PolkFan1 wrote:
    I am planning on buying a cd player that has HDCD compatibility. The Denon DCM 390. I am only going to be using the analog connections to hook up the cd player to my stereo 2 ch. receiver.(The red and whites). Will I still be able to obtain HD signals?
    Yes, but the DACs in the player will be converting the digital signal to analog
    God shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8
  • PolkFan1
    PolkFan1 Posts: 130
    edited March 2007
    Is that good or bad? I am not losing out on anything using analog connections right?
  • Lowell_M
    Lowell_M Posts: 1,660
    edited March 2007
    Yes, you are doing the right thing if the DAC in the CD player is what you prefer to use. (which will get you the HDCD decoding) Just use decent interconnects and not the free ones that come with CD players.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
