HDCD Hookup
PolkFan1
I am planning on buying a cd player that has HDCD compatibility. The Denon DCM 390. I am only going to be using the analog connections to hook up the cd player to my stereo 2 ch. receiver.(The red and whites). Will I still be able to obtain the HDCD format from the cd player?
Post edited by PolkFan1 on
PolkFan1 wrote:I am planning on buying a cd player that has HDCD compatibility. The Denon DCM 390. I am only going to be using the analog connections to hook up the cd player to my stereo 2 ch. receiver.(The red and whites). Will I still be able to obtain HD signals?
Yes, but the DACs in the player will be converting the digital signal to analogGod shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8 -
Is that good or bad? I am not losing out on anything using analog connections right?
Yes, you are doing the right thing if the DAC in the CD player is what you prefer to use. (which will get you the HDCD decoding) Just use decent interconnects and not the free ones that come with CD players.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
