Cables and Arrows???
PolkFan1
PolkFan1 Posts: 130
i have a set of monster rca cables red and blue with the directional arrows on it. I am trying to hook up the cd player to my stereo receiver and I do not know where I should plug the ends of the monster cables with the arrows into?
Post edited by PolkFan1 on
  • Lowell_M
    Lowell_M Posts: 1,660
    edited February 2007
    Follow the arrows.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • Lowell_M
    I have a Monster sub cable and took the arrows to mean...this is the direction that the signal shoudl go....So the arrow points from the receiver to the sub. I'm not sure why it woudl make a difference.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • PolkFan1
    PolkFan1 Posts: 130
    do the ends with the arrows go into the cd player or the receiver...?
  • Lowell_M
    Arrows point into the receiver.
    ...Not really sure why it matters though, but that is the direction the arrows are "supposed" to go.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • Sherardp
    Sherardp Posts: 8,038
    shouldnt matter, just make sure they correspond on both components.
  • beardog03
    beardog03 Posts: 5,550
    a_mattison wrote:
    Follow the arrows.
    what he said...
    arrows from source to pre (Rec), from pre/amp to sub
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • danger boy
    danger boy Posts: 15,722
    follow the arrows on the cables. or your music will play backwards.. giving you a message to kill your cat. :p:p
    PolkFest 2012, who's going>?
  • beardog03
    wwwwaaaaaaaaaaaaaaaaaaaaaaaaaa
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • ben62670
    ben62670 Posts: 15,969
    The Chinese cables when hooked up back wards tell you to eat your cat.
    The arrow signifies the direction of signal IE it starts from source then goes to receiver/pre amp. Pre amp to Amp/Sub
    Ben
