Cables and Arrows???
PolkFan1
i have a set of monster rca cables red and blue with the directional arrows on it. I am trying to hook up the cd player to my stereo receiver and I do not know where I should plug the ends of the monster cables with the arrows into?
Post edited by PolkFan1 on
Follow the arrows.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables -
I have a Monster sub cable and took the arrows to mean...this is the direction that the signal shoudl go....So the arrow points from the receiver to the sub. I'm not sure why it woudl make a difference.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
do the ends with the arrows go into the cd player or the receiver...?
Arrows point into the receiver.
...Not really sure why it matters though, but that is the direction the arrows are "supposed" to go.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
shouldnt matter, just make sure they correspond on both components.Shoot the jumper.....................BALLIN.............!!!!!
a_mattison wrote:Follow the arrows.
what he said...
arrows from source to pre (Rec), from pre/amp to subCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
follow the arrows on the cables. or your music will play backwards.. giving you a message to kill your cat.
PolkFest 2012, who's going>?
wwwwaaaaaaaaaaaaaaaaaaaaaaaaaaCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
The Chinese cables when hooked up back wards tell you to eat your cat.
The arrow signifies the direction of signal IE it starts from source then goes to receiver/pre amp. Pre amp to Amp/SubPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben
