attaching paintable speaker cable to walls
fiesta Mojo
I ran my audio setup (RM6800, thank you!) with Monster Navajo paintable cable. . . any ideas, or opinions out there on attaching said cable to a latex painted wall? I was told by someone of some stuff he thought was called "gum drop" made just for sticking speaker wire to "stuff", but I can't seem to find anything. . . I was thinking of using a craft hot glue gun; I asked Monster tech support about it, but they just tried to sell me "cable clamps" - made by Monster of course! appreciate any input on this. . . (I do plan to paint the cable) thanks!
Post edited by fiesta Mojo on
If you MUST run cables to the outside of your walls, I don't think there would be any detrimental effect to the wire insulation from the heat of the glue from from your gun. Personally, I think your on the right track. Ideally, if your not renting, I would install the wires behind the baseboard molding for a cleaner look. Some moulding have channels especially made to accomidate wiring. You may even try to remove some of the 1/4 molding if you have this and there may be enough clearance under the baseboard molding to tuck your wires. You could even shave some of the back of the 1/4 molding to accomidate your wire if its not too thick. It really depends on how much time you have on your hands and how clean a look you want. If your running cables up the wall, Home Depot have paintable plasitic wire channels as an option to hide your wiring. Hope this helps.Pioneer VSX-1016TXV-K AVR
Polk RTi4 surrounds
Polk CS300 center
Polk RTi8 fronts
Velodyne DSP-12 sub
Panny TH42PX60U 42" 1080i
Panny DVD-S53 DVD
Bell 9200 HD PVR
Harmony 880
Panny Blu-Ray -
Use the glue gun it will work just fine.My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool: -
thanks for the input. . .
