attaching paintable speaker cable to walls
fiesta Mojo
fiesta Mojo Posts: 3
I ran my audio setup (RM6800, thank you!) with Monster Navajo paintable cable. . . any ideas, or opinions out there on attaching said cable to a latex painted wall? I was told by someone of some stuff he thought was called "gum drop" made just for sticking speaker wire to "stuff", but I can't seem to find anything. . . I was thinking of using a craft hot glue gun; I asked Monster tech support about it, but they just tried to sell me "cable clamps" - made by Monster of course! appreciate any input on this. . . (I do plan to paint the cable) thanks!
Post edited by fiesta Mojo on
  • Carl333
    Carl333 Posts: 38
    edited February 2007
    If you MUST run cables to the outside of your walls, I don't think there would be any detrimental effect to the wire insulation from the heat of the glue from from your gun. Personally, I think your on the right track. Ideally, if your not renting, I would install the wires behind the baseboard molding for a cleaner look. Some moulding have channels especially made to accomidate wiring. You may even try to remove some of the 1/4 molding if you have this and there may be enough clearance under the baseboard molding to tuck your wires. You could even shave some of the back of the 1/4 molding to accomidate your wire if its not too thick. It really depends on how much time you have on your hands and how clean a look you want. If your running cables up the wall, Home Depot have paintable plasitic wire channels as an option to hide your wiring. Hope this helps.
    Pioneer VSX-1016TXV-K AVR
    Polk RTi4 surrounds
    Polk CS300 center
    Polk RTi8 fronts
    Velodyne DSP-12 sub
    Panny TH42PX60U 42" 1080i
    Panny DVD-S53 DVD
    Bell 9200 HD PVR
    Harmony 880
    Panny Blu-Ray
  • louthewiz
    louthewiz Posts: 581
    Use the glue gun it will work just fine.
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
  • fiesta Mojo
    thanks for the input. . .
