LSI15 hook up
Dan Carter
I purchased LSI15s powered by my mint Pioneer SX 1250. I aiso have a great Pioneer SX 1050. Should I biamp these Speakers or biwire only with the SX 1250?
Post edited by Dan Carter on
Wire them direct first since they require lots of power to make them sound great.My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool: -
I would bi-wire. It is the "cheaper" way to go, but I have been doing it for along time and it sounds great.
I am guessing you would use either the "B" or "C" terminals to do this. I know I read somewhere that the SX-1280 (I'm guessing the 1250 would be the same) could drive all three sets of speakers at at 180 wpc at the same time. If this is true then a biwire would definitely be beneficial.God shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8
did you try replacing the stock jumpers with good speaker wire? you might try that first and compare vs. bi-wire, might spend those dollars saved on something else. I have found that small tweaks such as this do not make a BIG difference as opposed to bi-amping,IMHO,good luck,have fun.:)JC approves....he told me so. (F-1 nut)
