Subwoofer Plate Amp Opinions
VR3
I am debating between two plate amps for my VMPS subs.
Both of them have the crossover defeat that I need.
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=300-806
http://www.madisound.com/cgi-bin/index.cgi?cart_id=4669957.25707&pid=452
To me the, Kiega would be the BEST match - considering the sub is 300 watts RMS and the Dayton is 500 watts. However I know watts mean nothing.
The Kiega is Class AB and the Dayton is Class G. Apparently Class G has excellent bass control - I do not know.
What are your thoughts?
Post edited by VR3 on
Don't get a plate amp.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Ditto what he said.RuSsMaN wrote:Don't get a plate amp.
You can probably find a used Crown K1 or K2 amp (no cooling fans) for the price of two plate amps. throw in a Paradigm X-30 crossover if you need one. The crown would be a much better amp and a much better investment than a plate amp.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
Well, I asked my electrical engineering professor...
The Dayton is a better match because it has servo controlled output, which means that it receives feedback from the woofer and delivers output accordingly.
Class G also provides better bass control than other types of amplifiers. They are extremely efficient and have low THD for subwoofer applications.
Edit: I can provide some kind of a schematic to describe what I am talking about. Basically Class G is a better choice over a class AB amp for subs. (Verified by my professor and also two electrical engineering textbooks)polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Perhaps has less issues with subs due to their inherant design, but I would throw a BS flag for any banket statment that states class of amp is better than another just due to the way that class works.appadv wrote:Edit: I can provide some kind of a schematic to describe what I am talking about. Basically Class G is a better choice over a class AB amp for subs. (Verified by my professor and also two electrical engineering textbooks)
I have never thought of replacing my amp (that is currently running my sub) with a plate amp. I would love to hear my SVS compared to another 25-31 that is powered by a plate amp though. (opus - are you listening???)
Getting a seperate amp and the seperate crossovers just isnt a very budget friendly method unfortunately. Atleast from what Ive seen. I definitely agree it would be a better method.
I really dont want to sink more than 500 total in the amps, shipped.
I need two channels, two crossovers, two phase switches, two crossover defeat switches with atleast 2 inputs.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
What about mounting the amps in an enclosure - away from the subwoofer to reduce its exposure to vibrations?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Couldn't you just split the output of the Paradigm X-30 into each channel of the Crown amp to power both subs? I use an Outlaw ICBM that has dual sub outputs to cross-over the bass in my HT system to my two SVS subs. I've seen used X-30's go for $45 to $85.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
McLoki wrote:Perhaps has less issues with subs due to their inherant design, but I would throw a BS flag for any banket statment that states class of amp is better than another just due to the way that class works.
To a large extent, Class G works better for subwoofer applicatons due to design, however I agree with you in sayiing that not all Class G amps are better than another just due to design...
From an engineering standpoint, Class G amps are extremely efficient, have very low distortion at low frequencies, and are quite responsive.
Now there are exceptions to the rule...polkaudio RT35 Bookshelves
If I was running straight LFE - splitting one large amp would work best...
However, I am running right and left stereo subs. So I really need that versatility to mess with phase, crossover, etc etc.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I would go one sub at a time. You might find you like the sound of the VMPS with just one sub. If you wanted to add the second sub later what a great option. You should give the sub every option to amaze you. The VMPS is a great sub and you will never know until you power it right.
Where is RUSsMan with his speach....Audio gear is a luxury....bla bla bal by the best and one up!!!!!!
Cmon' Trey do the right thing. My carver is 380 wpc and the vmps loves all the power!!!:eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More"
Sony cx985v (for now)
BBE 482i
B&K AVP 1030
Adcom GFA 555 mk 2
AudioQuest Crystal 2 spk wire
Nordost RCA
SDA 3.1 tl RD0 tweets
Belkin pf60
Carver TFM 55x
Signal Analog 2 RCA
AudioQuestType 4
VMPS Original Tall Boy (Mega Woofers soon) -
Sid, didn't you hear what Russ said? Forget about a plate amp. Do it right or don't do it at all. I realize VMPS uses slightly modified PE plate amps, but you'll want better quality.
At least get a pro amp to power your subs along with an external crossover.
I went from a very good plate amp (Rhythmik Audio) to using a single channel on a pro amp (Behringer A500) and it was a huge leap in sound improvement.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Paradigm X-30 has stereo inputs and outputs for the high pass, the low pass signal is summed for 1 or 2 subs outputs. There is volume knob and a variable phase that controls sub 2 output. These are 100-120 or so used.
Add an amp and bingo.
Outlaw ICBM is good for crossover and it has a level adjustment also, no phase adjustments.
RussDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
I'm driving my SVS sub with a Rythmik Audio 350A plate amp. It sounds great.
http://www.rythmikaudio.com/nonservo_product.htmMonitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
jakelm wrote:I'm driving my SVS sub with a Rythmik Audio 350A plate amp. It sounds great.
I had the 250SE version. The pro amp sounds better for roughly the same cost. You can get a decent brand new pro amp for $169.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Vr3MxStyler2k3 wrote:What about mounting the amps in an enclosure - away from the subwoofer to reduce its exposure to vibrations?
I did that already. It didn't matter.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Early B. wrote:I had the 250SE version. The pro amp sounds better for roughly the same cost. You can get a decent brand new pro amp for $169.
While I agree Early, I stil prefer the crossover and rumble filter built on the plate amp. And not rellying on the AVR. And the plate amp is on the sub, out of the way, another shelf is not needed.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
jakelm wrote:While I agree Early, I stil prefer the crossover and rumble filter built on the plate amp. And not rellying on the AVR. And the plate amp is on the sub, out of the way, another shelf is not needed.
Good points.
Sid is dealing with stereo subs for the purpose of improved sound quality. If he uses plate amps, he compromises the bass quality and defeats the purpose of what he's trying to achieve. If he were using the subs strictly for HT, it wouldn't be a big issue, but since Sid has elevated his game to much higher end gear, he needs to stay consistent and not get cheap all of a sudden with effin' plate amps. That's a step backwards. What's next, Sid -- Monster cables?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I use my avr filtering at 90 hrz. I have great results. I am very lucky. My avr has 2 sub out feeding into the TFM left and right. AudioQuest spk wire to the two subs in the same cabinet and it sounds great! I can control the sub level from a button on the avr remote is a plus.
BBE 482i
B&K AVP 1030
Adcom GFA 555 mk 2
Nordost RCA
Belkin pf60
Carver TFM 55x
Signal Analog 2 RCA
AudioQuestType 4
Dangit.
I knew I shouldnt have asked.
Grrrr.
Paradigm X30 and... hmm, maybe a Crown XLS amp.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Look at the RBH sub amps. We got the 200 watt one with a sub for a stellar price (like $250). I believe you can defeat the crossover, has phase and looks really good
God shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8 -
Early B. wrote:Good points.
Early, I respect your opinion. But I disagree in the fact that he will compromise his sound quality with a plate amp. Plate amps are built for the soul purpose of a subwoofer. They are built to handle the demand of power a sub asks for. If he was shopping for mains (full range) speakers, then yes, no question. But for the sub, I believe a good plate amp works just as well, if not better, than a pro or home amp.
Phase might be another issue Sid may have. Especially with 2 subs at once. I dont think (I might be wrong) a pro amp has the capability to adjust phase. Unless you reverse the positive and negative.
But I stand by my original thought, seperate plate amps for seperate subs would do just fine.
Jake
P.S And there is nothing wrong with Monster cables,.....LOL..:DMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Sid, I have an X-30 I can sell you.....
Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Vr3MxStyler2k3,
There is absolutely nothing wrong with using a plate amp for this application. Although pro amps may provide better sound quality, it is too much trouble IMO to go through an external crossover.
The purpose of the plate amp is to provide flexibility in your setup, in which a crossover defeat, LFE direct in, etc. are available.polkaudio RT35 Bookshelves
It's no trouble at all, it's one more set of interconnects. That's all.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
I might be wrong, but the plate amps should be well matched to use in subwoofer applications. Why does using plate amps compromise the sound quality?polkaudio RT35 Bookshelves
Trey,
Work a deal with your manager to test some of the pro-audio gear that you sell on a daily basis, with your subs, once they arrive. No harm in asking.
DGHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Russ are you for real?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
well, tommorow when I go into work I am going to check out the Crown XTi1000 and see how much fan noise it has.
if it isn't significant to me, Ill see about taking it home and giving it a go.
And the Paradigm X 30 for the crossover. Thanks Russ.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Just keep in mind that you can always swap out the fans with fans that are much more quiet. I bought the pro amp that powers my sub used and the guy had already switched out the fans. They're pretty quiet now.Vr3MxStyler2k3 wrote:well, tommorow when I go into work I am going to check out the Crown XTi1000 and see how much fan noise it has.
And the Paradigm X 30 for the crossover. Thanks Russ.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
tryrrthg wrote:They're pretty quiet now.
What is pretty quiet?
When I used a pro amp, fan noise was a problem, so I am interested in these quiet fans.Dodd - Battery Preamp
