Ring tweeters...
har_navalta
har_navalta Posts: 957
edited December 2002 in Flea Market
I'm not affiliated with it, maybe someone interested with
these tweeters...
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=3276&item=1946675511&rd=1
Look like Polk LSi's Ring tweeter...
a Vifa...Vifa XT-25 Ring Radiator Tweeters
Post edited by har_navalta on
  • hotwheelman
    hotwheelman Posts: 1,300
    Looks like some sub contracting going on here, is vifa who they are using to build their ring tweeter? naaaaaaa could be?
    "Its worked so far but we're not out yet."
    "Hey big man let me hold a dollar"
  • RuSsMaN
    RuSsMaN Posts: 17,985
    Yes, Vifa makes the tweeter for Polk, it is modded to Polk specs.
    You can buy the 'standard' version from Parts Express for $60 each.
    Cheers,
    Russ
  • hotwheelman
    Guess I havn't took enough time to look through my cat. from the express. thanks for the info I believe I will get mine out now.:D
  • brettw22
    brettw22 Posts: 7,623
    The Vifa's look like they would be able to fit into where my Tri-Lams are with my RT16's. Two questions:
    1. Can you just swap tweeters alone and be ok? or....
    2. Do you also have to replace the crossover for it to work properly?
    If I can make the Tri's a lil more subtle (replace them), I'd be 100% happy with the 16's. Overall it's not a big problem with the brightness of them, but on the weekends when I'm treating my neighbors to the music I find enjoyable, I sometimes get too much from the tweets.........
  • MxStYlEpOlKmAn
    MxStYlEpOlKmAn Posts: 2,116
    On your receiver, turn the treble down to -1. I have found this very effective, and they sound better. If their still to bright. Lower the Treble to -2.
    Damn you all, damn you all to hell.......
    I promised myself
    Damn you all! - ATC
  • hoosier21
    hoosier21 Posts: 4,432
    oops
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • RuSsMaN
    Brett, check with Ken @ Polk cs. Find the Vifa tweeter at partsexpress.com, and get the ohm rating (4 I believe), efficiency, and the resonant freq. Polk can then tell you if it's a match for your 16's. I don't believe its a 'drop in' match, but could be worked in with a simple in-line network mod.
    Cheers,
    Russ
    Ps, anyone seen Hunter? (my number one fan)
