Center channel height off floor
doug lang
doug lang Posts: 261
I will be putting a center channel below my tv. I am thinking of a stand by Dayton listed at
www.parts-express.com. The highest stand is 22'' With my lsic it comes to a total of 27". Would this be a correct height or should it be higher to match my fronts which are
32" at tweeter height. By the way the fronts are a perfect height when sitting. One final question is it best not to hang the center and have it away from the wall on a stand.
Thanks as always for all your help, i am almost completed with the installation of my system. Doug
Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Polk LSiFXs (surrounds)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
Post edited by doug lang on
  • doug lang
    edited February 2007
    I have checked a number of center stands and 22"s seems to be the highest stand. I guess i have answered my question. It will be lower than my fronts, there is no option.
    Integra DTR-80-2
    Polk LSi9s (mains)
    Polk LSiC (center)
    Sub SVS 20-39+
    Samsung 60" Led 3-d
    Blue Jean Cables
  • danger boy
    danger boy Posts: 15,722
    your center can go above or below your TV... if it's to high up or to low... use something to tilt it up towards you.. i have mine about 6 inches below my tv.. and tilted up slightly..
    once properly set up and the levels set.. it should sound pretty good for you.
    PolkFest 2012, who's going>?
  • doug lang
    Yes it may be a little low,but i will prop up as you did. Also all levels will have to be adjusted and tested. My room is three feet wider now. Love that plasma.
    Integra DTR-80-2
    Polk LSi9s (mains)
    Polk LSiC (center)
    Sub SVS 20-39+
    Samsung 60" Led 3-d
    Blue Jean Cables
