Center channel height off floor
doug lang
I will be putting a center channel below my tv. I am thinking of a stand by Dayton listed at
www.parts-express.com. The highest stand is 22'' With my lsic it comes to a total of 27". Would this be a correct height or should it be higher to match my fronts which are
32" at tweeter height. By the way the fronts are a perfect height when sitting. One final question is it best not to hang the center and have it away from the wall on a stand.
Thanks as always for all your help, i am almost completed with the installation of my system. Doug
Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Polk LSiFXs (surrounds)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
Post edited by doug lang on
I have checked a number of center stands and 22"s seems to be the highest stand. I guess i have answered my question. It will be lower than my fronts, there is no option.Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables -
your center can go above or below your TV... if it's to high up or to low... use something to tilt it up towards you.. i have mine about 6 inches below my tv.. and tilted up slightly..
once properly set up and the levels set.. it should sound pretty good for you.PolkFest 2012, who's going>?
Yes it may be a little low,but i will prop up as you did. Also all levels will have to be adjusted and tested. My room is three feet wider now. Love that plasma.Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
